High oil consumption
CB Engineering Swirl Valve removal
CB Engineering EGR delete
edit: I guess this thread was at the bottom of Bluetec oil consumption thread and I inadvertently posted a reply here.
bad rings or bad valve stem seals is a good bet
the venting system could be blocked as well
Replacing turbo was leaking by brand-new turbo. Hoping will fix the issue.
One quarter every 200 miles (ca. 322 km) of oil was burning and smoke only visible when not in reggen cycle is off, and at stop and go traffic, between lights and going up on free way ramps, no smoke at idle.
Last error codes were: turbo actuator faulty high crankcase pressure, boost issue/failure. These codes will only pop up after hard acceleration and not while in idle or smoothly driving.
DEF fluid level not going down even when/after reg gen cycle has been on according to OBD readings. So need to refile with Def to see if it is using Def during reg gen cycle.
Currently waiting for new gasket for tube reinstallation in progress.
Hoping new turbo oil seals don't go bad if DPF is blocked. But going to run some dfp cleaner in gas tank and drive smoothly after turbo installation and see if reg gen cleans DPF/ catalytic converter from all does 1400 miles (ca. 2,253 km) off burn oil coming from turbo internal leak. Yes, all other, oil separator membrane is new. This car is a mess. But I own a 2011 sprinter van with 190k and had bad EGR because issue will go away after EGR was cleaned . So Mercedes replaced catalytic converter and computer module caprylic convert/DPF and the problems just went away with new turbo. The issues were sever hesitation in taking off in traffic and city driving or going up ramps to highway then limp mode and the last symptoms were no turbo kicking and high RPM like a transmission issue. So the new turbo solved all issues but there was no oil consumption while these issues were acting up with the sprinter.
So the GL 350 has basically same engine has the sprinter but complete different emission EGR and turbo systems. I believe the GL 350 has bad turbo. Because sprinter did not blow turbo. Even with a bad/clogged DFP filter. It will literary just come off limp mode after using. DFP cleaner in gas tank and it will come back to life, but the EGR will act up and after cleaning will go back to normal. And finally new turbo everything is running fine. SO GL350 has had the same symptoms but with oil leak from turbo internally.
SO Mercedes has a big mess going on here, even Mercedes technicians don't know what is going on. They have brand-new sprinter Amazon vans with the same type of issues sitting across the country. In most Mercedes dealers( EGR serpentine belts issues.)
i will update my results after installation of new turbo ..
