400E 722.3xx Trans Fluid Capacity + Engine Oil
So I now have a '92 400E with 153k miles. It's in very good condition, it appears well kept. I acquired it because the previous owner passed away but the family has not (so far) located any service records.
I'm wanting to go ahead and do complete trans service including replacing torque converter fluid. Having a ridiculous time so far trying to find online info on how much fluid it will take to do the -complete- fluid change. What I've found so far is about 7.7 liters needed for trans service but there's no mention if this actually includes torque converter change as well.
Also, what is your opinion of best fluid to use, I'd appreciate that too. I've heard Mobil ATF D/M is what most dealers use. True?
And, engine oil, what brand especially and what weight is best with this many miles? I live in So Cal, not exactly harsh conditions.
Thanks in advance!!
mbnewbb
The magic number is 8 quarts if both trans and torque converter are drained. I don't think I got 8 quarts but close to it.
The biggest problem for me was accessing torque converter bolt...you have to turn engine until the bolt aligns with the little whole of the torque converter and even than exhaust will be in your way. I got ball point 5mm socket and it worked easily after that.
Check this links:
http://www.500eboard.com/forums/showthread.php?t=640
http://www.pelicanparts.com/techarti...ter_Change.htm
https://www.google.com/search?q=5mm+...=1512498951764
I have pictures and I can send it tonight if I find them. Yes it drains over the exhaust but not a lot at all...
