Help a Noob Mechanic Find a Coolant Leak
Old Dec 1, 2017 | 03:17 PM
Imanolg's Avatar
03 E500, 89 300E
Hello all,
Recently I purchased a 1989 300E for the sole purpose of learning to work on cars. I’ve always loved cars and always wanted to work on them, but I don’t even know how to change the oil. So, I figured that with the endless resources the internet has to offer and a lot of patience the best way to learn would be to buy an old car and try fixing things one by one.
This brings me to two days ago, when I found a W124 that was decent enough and had enough wear and tear for me to learn how to do all sorts of things. When I bought the car it was obvious that the car was leaking A LOT of coolant. I’ve spend a bunch of hours today trying to troubleshoot the issue to no avail.
After draining all of the coolant left on the car I can say that it is not mixed with any oil. I also looked at all of the hoses leading to the radiator and they don’t seem to be leaking either. So I filled the coolant of the car and started it up even drive it I just left it there idling, immediately coolant just started dripping heavily from the bottom and half the coolant tank was empty in minutes.
I took a few pictures of where the leaking is coming from, but to be completely honest I don’t even know what part of the car I am looking at.
This is where all of the coolant was collecting in the bottom of the car.
This is the same spot just a bit higher.
Also the same spot, a bit higher.
Do any of you have any recommendations on what I should try to do next to try to fix this issue?
Thank you!
Old Jul 9, 2018 | 09:26 PM
300CELOVER's Avatar
1996 SL500
Hey Noob,
Well, you can't STILL be a noob after 7 months, eh? If you still need help write me.
Old Jul 10, 2018 | 12:28 PM
teahead's Avatar
1994 e320 coupe
Was it fixed? If so, what was the issue?
NOt sure if a water pump failure would cause it to leak THAT bad. Maybe just a hose?
