wider tires for 1993 E500?
Old Apr 15, 2002 | 07:01 AM
mayolives's Avatar
The stock tires are worn out on my E500 and I would like to replace the 225 55 16s with 245 50 16s. The none stock size is 1" wider but has the same diameter (25.6"). Will they fit the body? Will I have increased tire noise? Has anyone tried this change? Will it handle better? Thanks for your coments.
Old Apr 22, 2002 | 03:08 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
u might wanna check if the the tires rub against either the inner wheel well or outer fender. if it doesn't, should provide a small improvement for handling. noise probably won't be too big an issue (but, there is more contact on the road)
