Window Multi Relay A124
1993 A124 300 CE 24valve
Hi guys,
I have a 1992 Mercedes A124 300 CE convertible with a faulty window multi relay control unit.
The part number on the unit is 124 820 54 26, Vin number WDB 124061 1B 009593.
One of the relays is not functioning, is this something that can repaired or replaced.
I cannot find a complete working unit to purchase, any leads would be much appreciated.
el.gizmops (08-04-2018)
Thanks for response. Havent been able to find 124 820 32 26, I have found 124 820 30 26 do you know if this is compatible. Your suggestions 09 26 starts with A202 820 09 26, I cant find anything with 48 26 .
Advice please.
Advice please.
Sorry i dont understand, "most the same on W124". I have taken a gamble and ordered a used 124 820 30 26,
came off the same model, will let you know if it works.
el.gizmops -
Plutoe is correct in that the cabriolet is unique and there are only a small number of part numbers that will work properly. Other controllers may work for most of the functions, but I think you will find that window control via the top function will be compromised with the wrong controller. See this thread for some more details: http://www.benzworld.org/forums/w124...onization.html
Hi Guys, my gamble appears to have paid off. Installed replacement module and now all window switches work up and down. I dont know what else should function( auto open etc) but at lease my initial problem of lowering prior to soft top opening is resolved . Onto next stage . Thanks to all.
