230E Always hot air in cabin
I have a 1993 230E in South Africa and in prestine condition with only one problem, namely that with the temperature control wheels in the cold position, hot air still flows into the cabin
I tried to search, but I am either too stupid to find threads or posts or nobody else has ever had such a problem, which I find difficult to believe
I suspect that the problem is with the HVAC heater control valve, also called duo valve or some rheostat perhaps under the dashboard
Can somebody please direct me to threads or walk me through a process of checking where the problem lies
Your assistance will be highly appreciated
Kind regards
Johan Louw ( Logged in as zsjad )
I don't have those type of controls (auto type), but are you saying whether the AC button is on or off, heat is coming out of the vents as if the dials were set to the HOT position?
To my mind it means that the hot water is never cut off from flowing to the heater core under the dash or wiper motor. I believe it is supposed to be done by the valve mentioned in my first post. I can't however not work out how this valve works. When I put 12 volts on the valve its electrical motor spins
Any advice out there will be appreciated
Kind regards
