abs light
Old Jul 14, 2019 | 04:29 PM
ddsmjg's Avatar
300TE
abs light
New to this site...I have a 1992 300TE in beautiful shape. I removed the gauge cluster to fix a stuck trip odometer. That went fine, but on putting it all back together, I find that the abs warning light does not come on when ignition is first turned on. Not sure why. It is not the bulb. Any help would be greatly appreciated. Thanks
Old Jul 18, 2019 | 07:38 PM
W124_oem_parts's Avatar
W124, W140, Alfa Romeo 166
Abs
Try to move the bulb a little or remove and put it back again and check the position you putting it behind the cluster you might be putting it in another position (check numbers)
