Fan blower ac heater not working
Old Aug 20, 2019 | 10:56 AM
Maximas's Avatar
1995 e420
I’m trying to fix my fan blower I already replaced the blower and the Heater A/C Fan Blower Regulator Resistor but that didn’t fix the problem. Checked the fuses and they seem fine . What could be the issue?
Old Aug 21, 2019 | 12:50 AM
cfrantz's Avatar
1987 MERCEDES 300E
You may have to break out the volt meter and track down where the voltage loss to blower is. Could be a relay, a wire, or even the control unit.
Old Aug 21, 2019 | 11:34 PM
Maximas's Avatar
1995 e420
fixed the problem with the fan it was the strip fuse by the fuse box. now i have to figure out why the ac doesn't blow cold and the middle outlets don't blow air at all.
Old Aug 22, 2019 | 09:02 AM
cfrantz's Avatar
1987 MERCEDES 300E
I forgot about that strip fuse. I have had that go out before also. The middle vents no working are typically due to failed blend door actuators, they have a tendency to leak vacuum and will have to be replaced. You might also check the vacuum distribution ports on the AC/Heater control panel and make sure it is working properly. AC not blowing cold can be a fuse, short in the feed wire, bad AC control panel, low refrigerant, AC relay, AC RPM sensor on the back of the compressor. If I remember correctly there is a 50 step test procedure to find the electrical failure if the failure isn't mechanical. This link should help, http://www.w124-zone.com/downloads/M.../103index.html
Section 83 is for climate control systems.
Old Jul 7, 2021 | 10:36 AM
Russell Ormerod's Avatar
not a merc
If you have xenon lamps Unplug them too
