Will 16x7.5 rims from a w140 fit my W124?
Old Aug 7, 2004 | 10:22 PM
E320Cabriolet's Avatar
95 E320 Cabriolet
I want to replace the 15" with 16" rims and found a great deal for a set from a '96 S-Class. Will this work? According to Tire Rack, when comparing similar rims, the off set is +40mm vs. +38mm. Bolt pattern is the same. Can anyone help?
Old Aug 7, 2004 | 10:54 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Originally Posted by E320Cabriolet
I want to replace the 15" with 16" rims and found a great deal from a set from a '96 S-Class. Will this work? According to Tire Rack, when comparing similar rims, the off set is +40mm vs. +38mm. Bolt pattern is the same. Can anyone help?
The holes in the wheel for the bolts are different, because the bolts used on the cars are different sizes. This is a pretty serious difference.
-s-
Old Aug 13, 2004 | 12:43 PM
300Penguin's Avatar
1993 MB 300E 2.8
It should fit. I have 17 X 7.5's on my car and had no problem fitting them. If you need proof check it out....http://members.cardomain.com/rideatmidknight
Old Aug 13, 2004 | 01:08 PM
Holson's Avatar
18 G550, 24 EQB3504M
They DO NOT fit.
The S-Class cars (W140 Coupe, Sedan, W220 and W215) and now the new W211 E-Class, and the ML SUV use lug bolts of 14mm diameter - the other cars use 12mm-diameter lug bolts.
