How do I get it to downshift???
Old Aug 10, 2004 | 12:48 PM
1994e320's Avatar
I have a '94 E320 that is a really great car. The only thing that really annoys me is that it refuses to downshift as far or as fast as I would like. It will not go down to 1st gear at slow speeds or sometimes down to 2nd from 4th when passing. Is there anything that can be done to the electronics to change shift points. I'd love for it to immediately find the lowest gear possible whenever the pedal is mashed against the floorboard.
Old Aug 10, 2004 | 05:34 PM
Jer's Avatar
Jer
1994 E320
When you floor the accelerator at a stop, the transmission should start in first gear. When you are accelerating normally, put the selector in 2nd then back to D to start in 1st gear. You can also get a 1st gear start kit from BergWerks. It is a modified valve body.
Old Aug 11, 2004 | 06:40 AM
doc willy's Avatar
w210 e240
i have tried try adjusting the bowden cable on my 93 E 320
and it is now very sensitive and kicks down aggressively.
i suggest to tighten the cable by 1/4 to 1/2 turn and observe
Old Aug 11, 2004 | 08:17 AM
1994e320's Avatar
Thanks for the reply. Pardon my ignorance, but what is the "Bowden Cable"? That is a term I have never heard.
Old Aug 11, 2004 | 08:20 AM
Jer's Avatar
Jer
1994 E320
The Bowden cable connects the throttle body (accel. cable) to the transmission. When you let-up on the accelerator the transmission knows you no longer need as much power, so it shifts up.
Old Aug 11, 2004 | 08:29 AM
1994e320's Avatar
Thanks again for the reply. Since I left the last message I did a little research and learned that bowden cable is the generic name. Sorry.
I'll give this adjustment a try. Thanks again for the tip.
Old Aug 12, 2004 | 03:35 AM
doc willy's Avatar
w210 e240
i remeasured my adjustment and it was about 1 full turn from from zero position (adjustment arrows are aligned) but i added an extra 1/2 turn.
92 E320: 104 engine
Old Aug 12, 2004 | 06:46 PM
349 BHP's Avatar
Mercedes E320 , Lexus IS350
where can you adjust this? i have the same problem as well
Old Aug 15, 2004 | 11:38 AM
doc willy's Avatar
w210 e240
its the cable that goes down to the transmission. the adjustment nut is at the left rear corner of the engine behind the fuel distributor. since i am not still satisfied with the response i tighten it again to 3 full turns from zero position and the sluggishness and slippage is not present anymore.
if you look at the cables behind the fuel distributor, there are two cables
one is from gas pedal and the other one is the transmission cable at the rear corner of engine head cover
Old Aug 15, 2004 | 03:04 PM
124-Fan's Avatar
Mercedes Benz
You should also check the fuses. If I remember correctly, current for the kick down switch in the floor under the gas pedal goes through fuse nr. 7. If that fails, the switch won´t work and the car won´t downshift normally.
Old Aug 24, 2004 | 07:41 PM
349 BHP's Avatar
Where is the adjustment nut? On the driver's side? Is it near the oil filter? Can you show me a picture of it please
Do i have to get under the car? Thanks for the help!!
Old Aug 25, 2004 | 11:44 AM
doc willy's Avatar
w210 e240
it near oil filter on my engine. the cable is link with the accelerator cable
Old Aug 25, 2004 | 12:38 PM
349 BHP's Avatar
Can i get more detailed instruction please
Does it look something like this:
Old Aug 25, 2004 | 08:06 PM
349 BHP's Avatar
Where is it near? A, B, C, D, or E?
Old Aug 25, 2004 | 08:21 PM
Jer's Avatar
Jer
1994 E320
PM me with your e-mail address, and I will send you the job for adjusting the Bowden cable.
Old Aug 28, 2004 | 01:36 AM
349 BHP's Avatar
i canttttttttt find ittttttttttttttttttttttttttttttttttttttttttttttttt
i guess it's diff for the 94 E class?
Old Aug 28, 2004 | 09:11 AM
Jer's Avatar
Jer
1994 E320
The Bowden cable probably does not exist in your model. As I said in the e-mail, the accelerator control is electronic, and as such, the transmission control probably is as well.
Old Aug 28, 2004 | 09:49 AM
1994e320's Avatar
The local Euro Garage told me that on the 94-95 E320's the link between the throttle and transmission is vacuum tube that can be adjusted down at the transmission. I haven't tried to find it yet...
Old Aug 28, 2004 | 10:32 PM
349 BHP's Avatar
let me know when you do please ... thanks
