M.104 running hot?
Old Jun 22, 2020 | 07:33 AM
Rafe's Avatar
1992 300CE
M.104 running hot?
On the open road my car"s water temperature is running at around 90 degrees C. In stop and go traffic the
temperature creeps up to 100 degrees C and sometimes a bit more. At a particularly long light you can watch the needle go up. The auxiliary fans kick in at about 105 C. Is this normal? I have replaced the thermostat, radiator, radiator cap, coolant (M
ercedes blue) and the fan clutch recently. My car is 1992 300CE with 3.0L M.104 engine. The photo was taken with the ambient temperature around 90 degrees F and the air conditioning on. I don't know if it is a related issue. The car is difficult to start when hot, especially if it has been sitting for 15 minutes or so. Fuel pressure seems to be good. Thanks for any advice.
Old Jun 22, 2020 | 09:52 PM
bicylindrico's Avatar
The fans should be kicking on more often with the freon high pressure switch instead of waiting for the engine temp to turn them on. Maybe check your high pressure switch and that particular circuit
Old Jul 1, 2020 | 10:40 PM
lululu's Avatar
94 e320s
GET IT CHECKED OUT, YOU HAVE 2 STAGES OF FAN OPERATION , AND OR YOUR FAN VISCOUS MAY NOT BE WORKING CORRECTLY
Old Jul 15, 2020 | 05:58 PM
M. Schneider's Avatar
1994 E-Class 320 Coupe, 1998 911 Carrera S (993)
Have a look at the A/C condenser for its airflow passage. A grimy dirty condenser will impede airflow. The radiator is new you mentioned...
