'89 300TE shift knob
Old Sep 8, 2004 | 01:01 PM
Bobenis's Avatar
2007 ML350 (M272) 30-509034 & 2008 ML320 CDI
Hello,
Does anyone know if the shift knobs on the earlier E class were permanently attached or can they screw off? Does just the knob screw off or is it one entire piece (knob and shaft) that comes out? I bought a really nice burl wood shift knob for my '89 300TE but I can not for the life of me get the original black spongey rubber one off. Cheers for the help.
Old Sep 8, 2004 | 06:49 PM
Sam 325i's Avatar
Turbo Diesel
Funny, I bought the same new knob. Mine's Zebrano Wood though.
You need to remove the edge cover of the shiftgate, then remove the wood around the shifter and window buttons via the 2 screws in the glovebox, then take apart the actual gearbox with the P,R,N,D,3,2 on it, and from there you should be good.
Sorry for being vague, but it was a while ago I did this.
Old Sep 8, 2004 | 08:31 PM
Bobenis's Avatar
So the knob does not come off the metal shaft? My new shift knob is just that, the knob, not the shaft. Is it possible to remove just the black spongey knob without the entire knob/shaft assembly?
Old Sep 8, 2004 | 10:17 PM
FiFth_StreetZ's Avatar
2008 E92 M3
hey i wrote a post with pictures that show u how u can change your shift knob here is the link, hope it helps http://www.bnzsport.com/forums/index...howtopic=13381
Old Sep 9, 2004 | 02:48 AM
Bobenis's Avatar
Hey thanks a lot for the pics and walk-through! I guess you can't keep the original shaft and put just a new knob on it? That is my question. The knob and shaft are all one piece and I will have to replace it all I suppose? THis is what I bought:
I need the whole assembly with the shaft attached, right? I cannot use the one above I guess...
Old Sep 9, 2004 | 12:37 PM
2008 E92 M3
u will need to buy a update shaft like i did...shouldnt cost alot..
Old Sep 9, 2004 | 01:58 PM
Bobenis's Avatar
Any ideas on where to grab one of those? I looked on eBay but didnt see anything. Cheers man.
Old Sep 18, 2004 | 12:15 AM
Bobenis's Avatar
I still can't find an update shaft. Do you have a link or place to where you bought yours from? Thanks man.
Old Sep 19, 2004 | 10:05 PM
2008 E92 M3
i got the update shaft along with my shifter...ask ur local MB dealer, they should be able to hook u up
