230E 1988 Footbrake Issue
Old Aug 19, 2021 | 10:25 AM
Unsyncable's Avatar
W124 230E
Exclamation 230E 1988 Footbrake Issue
Good day everyone! thank you for taking the time to help out a new owner!
I own a 1988 230E here in the Philippines and I have recently encountered an issue regarding my E-brake
It does not release completely.
The footbrake is strong and works perfectly, but when I want it not to work I have to pull the footbrake pedal while pulling the release lever too.
If I just pull the release lever the footbrake pedal only comes up 10% and the E-brake indicator is still on, on my dashboard.
Any help would be appreciated thank you so much!
Old Aug 27, 2021 | 12:55 PM
Trevor Hadley's Avatar
mercedes w123 260e
I find spring return on the brake cable might be missing see picture Also other information tell you to replace front brake cable ..
Old Aug 29, 2021 | 11:20 AM
Unsyncable's Avatar
W124 230E
Thank you so much sir! I will look into this!
Old Aug 29, 2021 | 11:45 AM
SpiderAce's Avatar
S63 AMG Coupe AMG GT55
It does sound like it's a mechanical issue. To add to Trevor's comment, if you seem to still have trouble, it is NOT uncommon for e-brake cables to corrode internal. The rust build up can make it difficult for the springs to retract. If the spring doesn't fix or help, just try working the cable by hand when it's disconnected to ensure there is no internal binding.
Old Aug 29, 2021 | 11:48 AM
SpiderAce's Avatar
Thumbs up
Great response and attachments. Helps us all, thanks.
Old Nov 2, 2021 | 11:43 PM
Unsyncable's Avatar
W124 230E
I have resolved this issue! Turns out the rust build up on the footbrake itself was causing the slow return when releasing. Just some good old WD-40 and everything was loose again
