Low, regular rumble/thrumming from exhaust W124 E280 (M104)
It used to idle silently but has had various engine issues since I changed the head gasket (and the head, with a used one from an R129, as the original was too corroded). I don't do much mechanical work and only have a basic understanding of things, so my mechanic has mostly been sorting these issues - primarily rough idle, which is now cured.
Another known issue is that the timing is off (retarded) by 5 degrees, but since this will have been the case before the head work I think it can be ruled out as the cause of the rumbling.
Could an engine issue cause this (something like misfiring messing with the timing of sound waves that the muffler is designed to deal with), or is it more likely to be an exhaust component? Any relatively easy tests I can do before taking it to a mechanic?
More details:
- Engine idles well at 600rpm and seems generally healthy, possibly slightly lacking in power, fuel economy OK
- There is sometimes a vibration/rattling from the back of the car; this has been particularly bad after a long drive
- I've just finished putting Kilmat sound deadening panels on the roof and sunroof as I thought all the flat metal areas might be resonating, but it hasn't made much difference to the exhaust related noise
When you say the timing is off by 5 degrees, do you mean it is off at the crankshaft? You may want to double check the timing marks on the crankshaft (dampener timing marks) versus camshaft timing marks one more time by removing the valve cover. On an M103 the ignition control unit sets the timing based on the crankshaft position as it has no idea what the cam timing is. And if the timing is off at the crankshaft that would point to a problem in the ignition system electrically. Not sure how it is on a M104.
But again I have no experience in M104 head installation, just asking questions.
That is how you fine tune the mechanical alignment on a M103. I assume it is also available on an M104.
So having the timing off by +/- 1.5 degree is acceptable to MBenz. Not sure about 5 degrees but I doubt you will even notice a 5% alignment issue. It will probably go unnoticed.
- Cheers!
- Cheers!
