Window Switch Left Front
Old Aug 1, 2024 | 07:08 PM
Handy930's Avatar
1992 300E
1992 300E 75,000 miles, driver window is acting up. Might go down and not go up. Sometimes it does nothing and later goes up part then down by itself.
All other windows work OK. Trying to find a replacement switch (unused) with out any luck so far. Part No. 1248208910KZ. Any ideas?
Thank you.
Old Aug 2, 2024 | 02:42 PM
Handy930's Avatar
1992 300E
Window latest: I tested right side with switch pulled l to find the up /down pin connectors. Jumped the LF switch holder..nothing but a little click. Window was down. Pulled the door panel
and jumped the LF switch. window went up. I found a new sw on Ebay with correct part number. Waiting for delivery. What would cause the click in the door?
when I connect the pin holes and the window did not move. I thought there was only one relay for all four windows. Does each window have its own relay the door?
If so how do you access it? Can I rule out the motor being a Problem?
