95 E320 will not crank
Old Dec 7, 2004 | 04:33 PM
kg95e320's Avatar
Cold start, happened suddenly - Inserted key, turned all the way, all lights came on, seatbelt buzzed, radio played, but engine didn't crank. Battery is 6 mos. old, tried jump anyway. Same thing. Ideas? Thanks, KG
Old Dec 7, 2004 | 06:07 PM
overboostTSI's Avatar
90 300e and B5 S4
Try putting the shifter lever in neutral and try cranking the engine again, if it starts then you have a bad neutral safety switch. If that doesn't work then it could also be a starter, ignition switch or something else.
Old Dec 7, 2004 | 09:56 PM
kg95e320's Avatar
Neutral safety switch it is. Thanks.
Old Dec 7, 2004 | 10:25 PM
electric blue's Avatar
Not Starting in Park
You could also have bad shifter bushings. I would have a mechanic take a quick look hopefully while your standing there with him under the car. This is not uncommon.
