Coolent Leak somewhere HELP!!!!
Old Jan 6, 2005 | 01:24 AM
e320newbie's Avatar
91' 300e // 99 300e TD // 00' ML55 AMG
2 weeks ago my coolent light lit up on the dash. so i filled er up and was proud of my handy work. so a week goes by and on my way to work my light comes on again. So durring the day i look out the front door at my car, and underneith it i see a small puddle forming, i dabbed it with a cloth and its my coolent fluid. so wtf where can it be coming from? some dink at a garage said over the phone it could be my water pump and said its 600 to fix . so that day i refilled the coolent and this morning that f-ing light came on again. i went through a 3l jug of coolent in 2 weeks. anyone know what could be wrong? Crossing my fingers. thanks everyone
Old Jan 6, 2005 | 03:45 AM
aquanote's Avatar
C 200
Well i believe that its the water pump that need to be fixed too..coz if the hose is broken than the puddle will be bigger. well i can find it the water pump if you want to replace it just let me knowww
Old Jan 6, 2005 | 03:57 AM
e320newbie's Avatar
finding the water pumo isnt the problem. i was told it will be hard to replace because its in a tricky spot or something like 5 hours labor . does that sound right ? or is it bs?
Old Jan 6, 2005 | 03:58 AM
e320newbie's Avatar
the puddle isnt huge, its a smaller leak but still enough to drain my coolent in a week
Old Jan 6, 2005 | 02:39 PM
mhorn's Avatar
1991 300E
Check the radiator neck at the top of the radiator going into the thermostat housing. The plastic Bher Radiators are notorious for breaking and leaking at that spot. Hope it's not the water pump becasue they are a ***** to get at. If you do get everything back watertight, be sure and use only Mercedes Benz brand antifreeze when you refill. This is one of the few things that the M-B brand is actually necessary. The regular green antifreez will corrode your cooling system.
Old Jan 6, 2005 | 11:07 PM
e320newbie's Avatar
mhorn i think ur right, im having it go in this weekend for a new tie rod and fix that leak problem. Ill be sure to get the mercedes anti-freeze, i never knew about that before. thanks everyone
Old Jan 7, 2005 | 01:14 PM
mhorn's Avatar
1991 300E
No problem, there is something about the differnet types of silicia that the Merceds Brand coolant has. They M-B brand supposedly will not harm the radiator. It is more a yellowish red color. However, when regular green coolant is mixed with the M-B brand, they interact and cause a lot of corrosion. I went to look at a 300E for sale and the seller was showing me the notorious spot on the radiator that was leaking. He barely touched that spot and the whole radiator neck broke off in his hands! Needless to say I passed on that car.
Old Jan 7, 2005 | 09:14 PM
e320newbie's Avatar
haha, so how do i get all the old fluid completely flushed before i fix the problem and add the new stuff?
Old Jan 10, 2005 | 01:13 AM
349 BHP's Avatar
Mercedes E320 , Lexus IS350
Whatever you do don't buy those "Stop Coolant Leaks" from gas stations, they make the problem worst.
Old Jan 10, 2005 | 05:09 PM
mhorn's Avatar
1991 300E
You can flush the radiator yourself, but having done it I would seriously consider paying a mechanic $100 to do it. There is a drain screw at the bottom of the radiator and there are drain plugs on the engine block. You need to drain and flush the fluid from both these areas before adding the new coolant. It's a pain and you have to make sure that you collect all the old collant so you don't violate about 30 EPA regulations and kill all the neighborhood cats.
Old Jan 11, 2005 | 03:44 AM
e320newbie's Avatar
haha
Old Jan 14, 2005 | 01:55 AM
Arnie's Avatar
08 Lexus GS350 AWD. 08 Lexus RX350 AWD - wife's. 94 MBZ E320 - still have it.
I would pressure-check the system before spending any money.
