hesitation on excelertion
Old Jan 16, 2005 | 03:25 PM
grymarkt300's Avatar
1992 300E
my 300 seems to be hurting.....when excelerating in first i gets no power to the wheels. It seems almost like someone is pushing on the front of the car as im trying to go forword, it doesnt want to move although 2nd,3rd & 4th gear are fine.... belive me its not the trans(my car is 5 speed). HELP!!!!
I Have Pics Though....
Attached Thumbnails hesitation on excelertion-my-car.jpg   hesitation on excelertion-another.jpg
Old Jan 16, 2005 | 03:29 PM
1992 300E
more
Old Jan 16, 2005 | 04:34 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
Could it be the brakes aren't releasing immediately? One way to test is to stop on a grade in neutral, then see if the car starts rolling after you release the brakes.
Old Jan 16, 2005 | 04:44 PM
Brian Felts's Avatar
E 320
Does the motor rev freely in Neutral? Does it feel like it has full power when you get to forth gear?
Brian
Old Jan 18, 2005 | 08:25 PM
1992 300E
yea well i have tomorrow to find out exactly whats wrong w/it and when i do i will let u all know. bye
Old Jan 19, 2005 | 06:36 AM
E 320
There are so many small things........Kestas could be right you could have a frozen caliper. I was thinking you may have a clogged cat or a blocked muffler. Could have a throttle sensor going bad.
Brian
Old Jan 22, 2005 | 09:44 PM
1992 300E
yes exhaust
Old Jan 23, 2005 | 02:33 AM
amt's Avatar
amt
13 E350
How to check when the car has clogged cat or a blocked muffler
Old Jan 23, 2005 | 11:03 AM
E 320
Milage will tell a tell of a clogged cat......then check the ammount of exhaust coming out of the tail pipe. There should be a instant rush when you rev the motor. Sound=volume and you should make fairly easy judgment call. If they are clogged use performance aftermarket Cats.......they are considerably Cheaper. www.summitracing.com or www.jegs.com.
Brian Felts
