1988 300CE or 1993 400E better? how about fixing up a 300CE? HELP ME PLEASE
how about getting new rotors and brake pads, whos should I look for in getting the rotors and pads for cheap?
how about how much to charge my a/c???
What wheels will fit the 300 CE and also I do like all the newer E-Class wheels like the AMG wheels off of an E-430 sport. Would CLK wheels fit an 300CE? What size is the perfect rim size for a 300CE and also what kinds of spring and shocks should i get?
How do I get an AMG copy kit for a 300CE???
Would you guys rather have a 400E or a 300CE???
sorry for all the questions but I just need your help in my searching for my next project.
thanks
Rotors and pads are pretty reasonable, any online place will charge about the same for them, try http://www.germanstar.net/
If you have the old refrigderant in your A/c system I don't know if you can still get it charged. But even if you can, charging won't do you any good unless you find where the freon is leaking out of. worst case to fix a/c $2 grand.
I don't know about wheels.
I would personally go with a 300E or E320 over the CE or the V8. They are cheaper and easier to fix. I would stay away from the early coupes. I think they had the squirelly motor in them the first couple of years.
I drive a 93 400E, and my last car was an 88 300E. I made sure that the car I bought had all maintenance records, and had the usual problems fixed already (wiring harness, etc...).
The difference between the two cars is definately a marked one. The 400 feels heavier and more powerful, and with bigger tires (a must-have mod) and brakes handles like a true sports sedan. At high speeds there's no comparison. The 300 always seemed underpowered for the highway. The 400 is a beast at high speeds, with a lot of torque and very tall gears.
Either way, you can't go wrong. The 124 is a great car in all its permutations. Good luck with your buy.
