Brabus wheels!
Old Mar 16, 2005 | 12:44 PM
Shane C's Avatar
E320
Brabus wheels!
Ok last week a guy in a jaguar flagged me down and gave me his card. this guy owns a body shop and said he has a set of 4 18" authentic brabus wheels painted and tires he needs to get em out of the shop I can have them for $300.00 (of course upon reciept). I'm going today to get them not sure what style but for this price it really doesnt matter Hell i would buy them if they were fake. I will post the outcome later today. My lowenhart 19's arent cutting it anymore I have been repairing constantly due to the road conditions here
Old Mar 16, 2005 | 03:20 PM
Shane C's Avatar
E320
wooooo wooooo I won the lottery I got em they are authentic 18" Brabus mono block IV (one piece) painted black unfortunatly they are one pice but hey $300 who cares will post pics tonight not sure how they will look on a Blue E?????? but definatly better than my stock wheels. bent 3 of the lowenhart BR5's so they will sit till I decide to spend $450.00 to get em fixed and get tired of these.
Old Mar 16, 2005 | 07:10 PM
MBZW210's Avatar
CL600
good stuff man.. ya i dont know why lowenharts are so weak, they are like $4000 wheels..I bent mine all the time before but now Im rolling brabus 6 replicas with no issues. post some pics
Old Mar 17, 2005 | 11:25 AM
Shane C's Avatar
E320
Yeah I have had all rims repaired a least twice and one 3 times! I am sick and tired of them!
Whitey/anyone know what spacers i will need to get the offset look I had with the 9.5 br5's the monoblocks are from an S class I also read in a thread that I will need spacers in the front to prevent rubbing. I would like to get the rear ligned up with the fender its (rolled).
Anyone know what size bolts?
Old Mar 17, 2005 | 11:47 AM
Whitey's Avatar
98 W210 Advantgarde
Wowie, they're a bargain!
What width and offset are they now? I can give you exact spacer required once you give me the size of the wheels. S offset is like ET41-43...you'll need at least 10mm spacers...but I'll need to know the width to be a little more precise.
If they came from an S, you might have the issue of the 14mm vs 12mm bolt (E spec) that we've been discussing endlessly but it's been done. As said, I wouldn't do it given the choice but I understand you can get special bolts to make it work...or else I can give you instructions on how to mod a 12mm bolt to fit...but that'll be a hassle and I'm not sure if I can show u over the web......
Lowenhart's are US$4000's?????? They're less than half here, considered cheap wheels here in Asia..... Hahahha, I could have sent u some, with shipping they'd still be cheaper........
Old Mar 17, 2005 | 12:00 PM
Shane C's Avatar
E320
$4000 would be cheap. mine (chrome BR5) were about $1500 each for the rear 9.5x19 and $1100 for the front 8.5x19.
I will get the numbers off the back of the rim to determine the exact setup of these they are 8.5x18 and from S class.
Old Mar 17, 2005 | 12:06 PM
Whitey's Avatar
98 W210 Advantgarde
Yep, I could've gotten u diamond cut ones for less....much less.
Mmmmm, 8.5" all round? U might need even thicker spacers then...but luckily, Brabus do have original ones so they fit perfect....expensive tho It was either bad ethics or ignorance to sell you wheels with 14mm bolt holes tho....anyway, we can hopefully make it work....wish u luck bro.
Old Mar 17, 2005 | 02:26 PM
Shane C's Avatar
E320
OK here is the scoop
412-858-35
8.5Jx18h2
ET 35
I really like the offset look and would like to space the rear out to fender if possible. I have seen some spacers on ebay pretty cheap!
If you know the right bolt size that would help a great deal too
thanx for the help !
Old Mar 17, 2005 | 09:36 PM
Whitey's Avatar
98 W210 Advantgarde
Yes, I know exactly what you are trying to achieve and I have been there.
In that case, its cool - 10mm for the rears, the fronts will be fine without any. Slap some 255's in the back (I presume you'll be usuing 235's in the front) and you'll get a staggered kinda look. I wouldn't use the cheap spacers, simply for safety..original Brabus if possible or else, other good hubcentric spacers (e.g. H&R) are the only way to go.
You sure the wheels came off an S? If not, then you're fine with the bolts, just need longer ones.......
Old Mar 18, 2005 | 01:35 AM
Shane C's Avatar
E320
not sure on the model there from? The guy thought they were from an S??? so I'll be cool with the front with ET 35!
I know that the rim does not fit "hub centric" since I have allready tried to get them on and there is some play once on the hub I suppose they couldnt correct this issue by having a different measurment on each side which would you recommend I order for E , S or?
Old Mar 21, 2005 | 12:32 PM
Shane C's Avatar
E320
Ok one more will a 265 35 18 tire fit the 8.5 rim without rubbing on the fenders if they are spaced out 10mm? found a deal on some?
Old Mar 21, 2005 | 12:49 PM
Whitey's Avatar
98 W210 Advantgarde
Noooooo....you will regret...the 265's will look like they will fall off...in fact, they MAY fall off!
BTW, I don't understand why they won't fit "hubcentric"....maybe you had the OEM hubcentric rings removed to fit the Lowenharts (as I have with mine). Did you see a silver colored ring in the center of the hub? If not, then they have been removed DO NOT DRIVE WITH THEM ON WITHOUT THE RINGS!!!!!!!!!
You will need to get those in order for your wheels to fit safetly. However, you won't need them if you use spacers for the rears cuz you will have to take them off to fit the spacer anyway and the hubcentric spacer should take care of the fit onto the rim.
Old Mar 21, 2005 | 01:44 PM
Shane C's Avatar
E320
OK what size should I get for the rear? The spacers will be hubcentric not sure if I have the rings you speak of but I will check.
Old Mar 21, 2005 | 01:52 PM
Whitey's Avatar
98 W210 Advantgarde
10mm, maybe 12mm if you like - my calculations tell me your fender clearance can afford up to 15mm but I'd not recommend such a thick spacer. Do check the rings cuz it sounds like you're missing them....to clarify, you will only need a pair for the fronts if you're doing hubcentric spacers.
Old Mar 21, 2005 | 03:02 PM
Shane C's Avatar
E320
yes I will stick with the 10mm spacers Not sure about tire width for the rear for offset look should I just stick with 235's or go up to 255?
Old Mar 21, 2005 | 04:19 PM
Shane C's Avatar
E320
called brabus and ordered the hardware kit which includes 10mm spacers and bolts for all 4 wheels apparently all i needed was 2 $10.00 brabus hub rings to correct the hubcentric problem.
Old Mar 21, 2005 | 08:28 PM
Whitey's Avatar
98 W210 Advantgarde
Good stuff! Glad it worked out quite cheaply (????? Cost of spacers?)...yes 255's.
Old Mar 22, 2005 | 10:14 AM
Shane C's Avatar
E320
Well it could have worked out cheaply if i just ended up with the rings but I went ahead and ordered a "hardware kit" bolts and 10mm spacers all around will not need the rings with the right spacers (2 different versions of these 1 piece rims) not sure on price yet around $300.00 they are going to email me the total.
