advice for tires please!
Old Mar 20, 2005 | 03:44 AM
Ben'z's Avatar
E320
Hi, all,
Please give me some advice for tires.
I am thinking about 235/45/17 all around, or 245/45/17, 255/40/17 in the rear.
What is your opinion?
Thank you very much,
Ben
Old Mar 20, 2005 | 09:21 AM
E-Klasse's Avatar
W205 C300
Before you go putting different tire sizes on, do a size calculation to make sure you are under a 3% difference.
Go here for the Tire size calculator
Having a staggered setup is good when you have wider rims in the back than you do in the front.
If you have 225/65/16 now, you can go to 245/55/17 with only a Diameter Difference of 0.37%.
Old Mar 20, 2005 | 10:01 AM
Whitey's Avatar
98 W210 Advantgarde
Originally Posted by benchang88
Hi, all,
Ben
Mmmmm, sounds familiar
Old Mar 20, 2005 | 10:47 AM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
Im goin with 235/45 in front,,,,,255/40 in rear
Old Mar 20, 2005 | 01:52 PM
Ben'z's Avatar
E320
Old Mar 20, 2005 | 02:01 PM
Ben'z's Avatar
E320
Hi, E-Klasse,
Thanks for the useful website!
Actually, the original are 215/55/16.
The new wheels are 17x7.5 and 17x8.5.
I have 235/45/17 all around, and thinking about wider for the rear.
Don't know how to make decision....
Old Mar 20, 2005 | 02:03 PM
Ben'z's Avatar
E320
Hi, Steve,
Will they rub?
What is your opinion not 245/45 in rear?
Thanks!
Ben
Old Mar 20, 2005 | 10:13 PM
E-Klasse's Avatar
W205 C300
235/45/17 would be the best fit compared to the 215/55/16 so you could do them on all 4 but to take advantage of the wider rims in the back, go with 255/40/17 in the back with only a 1% difference.
Old Mar 21, 2005 | 08:32 AM
stemags's Avatar
E klasse is right,,,and I got the idea from Whitey,,,and it is also recommended by Tirerack....235/45-17 in front,,,7.5" rim,,,,,and 255/40 -17 in rear on a 8.5" rim.That should be fine,,,but if youhave any other doubts,,,Dave(Whitey) is the wheel guy.Should not rub,,,but you need to consider the ET to be sure,,,again,,,help the man Whitey!!!!!!!
Old Mar 21, 2005 | 12:39 PM
Whitey's Avatar
98 W210 Advantgarde
OK Steve (and Ben), as E-Klasse said, 255/40 will only give you a 1% error (1.2% actually) i.e. your speedo will be faster by 1.2% than your stock setting e.g. when your speedo reads 60mph, you're actually travelling 59.3mph - not enough to notice on an analog speedo and a little extra safety margin, one might say
I'm assuming you got the staggered setup for those W203 Style IV's so it'll 8.5"/ET34 in the rears, right? If so, by way of comparison, with those wheels you will have 5mm more fender clearance than the standard E55 setting using 9" ET35 wheels (which I have used in the past without problems). N.B that's just the wheels, your narrower tires will also give you a little more clearance (at least 5mm) than the E55 recommended setup using 265's. For added assurance, your internal clearance will be 7mm more than the AMG setup. Conclusion? NO RUB - go for it buddy! For a little extra "staggeredness" you might want to consider a 5mm spacer in the rears - that will give you an "E55 look" fender clearance - good luck!
Old Mar 22, 2005 | 04:08 AM
Ben'z's Avatar
E320
Thank you so much, Dave!
One more question, I might be wrong, I think the speedo will read from the front tire, right?
Then, 235/45/17 in the front should be read very close to the original setting. :p
Thanks, again!
Ben
Old Mar 22, 2005 | 10:58 PM
E-Klasse's Avatar
W205 C300
The rear tire size makes the difference in the speedo. The speed is measured in the transmission.
Old Mar 23, 2005 | 02:15 AM
Ben'z's Avatar
E320
E-Klasse, thanks so much!
Ben
Old Mar 23, 2005 | 02:49 AM
Ben'z's Avatar
E320
:p
One more question, is that OK front and rear tires from different brands?
Please forgive my stupid!
Ben
Old Mar 23, 2005 | 03:30 AM
geunkmail's Avatar
yo, ben. what wheels did you get for your ride? just curious
Old Mar 23, 2005 | 05:26 AM
Whitey's Avatar
98 W210 Advantgarde
:p
Ben
Best for them to be matched but if you really must, get ones with similar looking tread patterns..........
Old Mar 23, 2005 | 11:37 AM
Ben'z's Avatar
E320
17" AMG style IV, double spoke, W203.
It is for C32, however, W209 looks better!
Old Mar 23, 2005 | 11:41 AM
Ben'z's Avatar
E320
I got a set of Goodyear F1 supercar with good price, 235/45/17.
It seems they will be expensive from retail.
That's why I am thinking about getting another one for rear.
Old Mar 23, 2005 | 01:15 PM
Whitey's Avatar
98 W210 Advantgarde
Actually the W211 ones look even better than the 209 version....but you'll need bolt mods since its not an exact fit (not recommended)
Old Mar 23, 2005 | 01:16 PM
Whitey's Avatar
98 W210 Advantgarde
What is the price of safety (and performance)??????
Old Mar 24, 2005 | 02:29 AM
Ben'z's Avatar
E320
Hi, White,
You are right!
I think I will keep these 235/45/17 all around for safety issue. :p
Thanks!
Ben
Old Mar 24, 2005 | 03:21 PM
zam2000's Avatar
S, GL, Escalade ESV, my shoes
Actually, the speedometer is synched with front wheels. I got the diagram, so I'm pretty sure that's the case.
Old Mar 24, 2005 | 03:39 PM
Whitey's Avatar
98 W210 Advantgarde
Hi, White,
You are right!
Thanks!
Ben
I meant having matching tire tread front and back, not the same width.......
Old Mar 24, 2005 | 04:11 PM
E-Klasse's Avatar
W205 C300
There are speed sensors for the ABS at each wheel but as far as I know, the Speedo take a reading from the back of the transmission where the drive shaft connects.
Old Mar 24, 2005 | 07:45 PM
stemags's Avatar
That sounds like the NAV has to be recalculated,to get proper positioning.Anyone ever do that,cause i think i might have to? Going from 235/45 to the 255/40.
