Procedure for removing door panel??
Old Apr 23, 2005 | 07:27 PM
TomBeverlyHills's Avatar
2001 CLK430, 2000 E320 Wagon, 1992 300CE (sold), 1998 C280 (sold), 1995 C280 (sold)
Does anybody have the procedure for removing the front door panels? I got it partially loose (some of it is obvious), but there is something holding the panel at the top that is not apparent. And I don't want to "guess" at how it comes off and break something in the process. Thanks.
TomBeverlyHills
E320 Wagon
CLK430
300CE (sold)
C280 (sold)
Old Apr 24, 2005 | 07:01 AM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
Sounds like maybe there is the screw behind the door latch,which has the plastic around the edge,which pops out to reveal it.(Phillips head,or maybe a torx).If its out and all the other screws are out,you have to push up on the door panel to lift it off the door.
TomBeverlyHills
E320 Wagon
CLK430
300CE (sold)
C280 (sold)
Old Apr 24, 2005 | 12:47 PM
EddieGTP's Avatar
Not a Benzer anymore
Try This Link...
http://www.edsoto.com/w210/disassembly_doors.htm
They make it look sooooooooooooooooo easy
Old Apr 25, 2005 | 01:07 AM
HTBenz's Avatar
Remove the SRS cover(in the door panel) and release the screw behind it. That could easily be the problem if you forgot to get that one.
Old Apr 25, 2005 | 04:11 PM
bingoldsby's Avatar
If you're sure all the screws are out - pull the panel UP firmly. Meaning get a good grip on the panel and pull straight up towards the sky.
Brian - Yakima, WA
2000 E320
Old Apr 29, 2005 | 12:53 AM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
Thanks for the video link, great question and posting. now I can do something about my door handle trim which is cracked. I was afraid to mess with it since the SRS airbag kind of scare me off. Once again, great post.
Old May 2, 2005 | 06:44 PM
EddieGTP
Thanks for the link to the video!!!! A video is worth 10,000 words.
TomBeverlyHills
Old Aug 19, 2005 | 03:04 PM
C240-Merc's Avatar
2017 G63 AMG, 2019 G550
EddieGTP, you wouldn't happen to know of a website that has these types of videos for c class MB's do you?
Old May 5, 2016 | 11:57 PM
R_Bzdel_E430's Avatar
2002 E430 4matic (W210)
Link is dead.
Old May 6, 2016 | 08:57 AM
illest's Avatar
w210 AMG or S213
thats weird it was only posted 10 years ago.
this video shows the process
Old May 6, 2016 | 11:38 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Darn Internet dies faster than those cars
The last video shows rear door panel, but procedure is pretty similar.
From the description OP had a problem to figure out that the top of the panel has reversed U trim that goes into glass slot. You need to push the panel up to have it come out.
