Rear speakers missing on E320 Wagon
2001 CLK430, 2000 E320 Wagon, 1992 300CE (sold), 1998 C280 (sold), 1995 C280 (sold)
My 2000 E320 Wagon doesn't have any rear speakers. That's because, of course, there is no rear hat shelf, so the normal place for the rear speakers isn't there in the wagon. As a result, the factory stereo (I think it's the optional Bose system) sounds like garbage because it has no bass because the rear woofers don't exist. I'm wondering if anybody knows whether the amp in the wagon is the same as the amp in the sedan. If so, I should be able to put some woofers in the back of the wagon and wire them to the existing amp. Does anyone know whether the amp is the same or not?
209/W210 Estate /W211 modded by MBENZNL
The W210 Wagon Does In Fact have a Sub With The Bose System....Look behind the Passenger side cover for the Cd changer Its There!
Im Not sure re the AMP part Numbers...Would have to look that one up.
1 Post
11 ML350W2 / 17 GLC300
Yes, the sub-woofer is behind the passenger side load area removeable panel. It looks like a lump in the upper left portion with a little circular grill like opening at the rear of the lump. I won't disagree with you about the quality of the bass.
