I Need A Damn Kit On My Car
2012 E350 4matic/97 e320 and 01 ml320
I need to fix my negative front cambers (ANY SUGGESTIONS?), i have steve's camber kit in the rear I have the camber bolts from the dealer, as you can see, they don't do sh*t!
(my cousin's 99 320 in front, my 97e320 in rear)
hell yeah that is bad *** mine are cambered as hell too. i do know of a camber kit for the rear. mine is about the same hieght as yours, my rear wheels are worse than the front. im running modified h&r's
Well guess what? I aint no ganster and I want to avoid going though front tires every few months. My rears are perfect, I got the adjustable rear camber arms from speed benz last year..he did not have front ones at the time. I'll try him again and see what he comes up with...
you would have to import that kit..........its a pain of a *** but i might be able to look into it for you......i wanted it for my ride but you know it cost a lot of $$$$
I had the same problem. This is the thing, with a drop that low if you fix the camber you might encounter some serious rubbing. It looks nice the way it is. If you fix the camber you might have to raise the front. Hope this helped
