Doors Locking Automatically
Old Jun 27, 2002 | 05:06 PM
Illona_Everlost's Avatar
Is there a way to make the car doors lock automatically when I drive off? My E430 used to do that until I took my car to the dealership yesterday and now i have to do it manually.
Any suggestions?
Thanks.
Old Jun 27, 2002 | 05:32 PM
jswedberg's Avatar
C32 AMG
What year is your E?
With W203 C class cars you can change the setting using the dash display and wheel buttons. Don't know if that is available on yours. On our ML, it is a computer setting settable by the dealer.
An alternative is to take it back to the dealership and tell 'em "whatever you did, undo it!"
Old Jun 27, 2002 | 06:09 PM
sael's Avatar
98 e320
Automatic door locking
To re-activate:
With the key in the steering lock position two press an hold the upper part of central locking switch for at least 5 sec.
Old Jun 28, 2002 | 06:38 PM
To re-activate:
Sael, I did as you suggested below and the doors are still not locking. FWIW, it's a 2002 E430.
Any other suggestions?
Thanks,
Old Jun 28, 2002 | 06:46 PM
ryson's Avatar
2014 E350, 2008 C300 Sport
Illona,
Check your manual. They give instructions on how to turn this feature on/off. When on, the doors lock automatically when you exceed 9mph. I think this is what Sael was trying to describe to you. But maybe your model has a slightly different procedure. Either way, it should be clearly explained in the manual under door locks.
Old Jun 28, 2002 | 07:37 PM
sael's Avatar
98 e320
The instruction I wrote were for a '98 e430 so there might be a diferent way for a '02 model. But Ryson is right check the owners manual it should be under doors or call the dealer.
