A/C error code question
Old Jul 18, 2005 | 07:48 PM
mbsickness's Avatar
1996 C36
Hi,
I have a '98 e320 (w210) and my A/C works but not well. I also noticed that my fan doen't seem to have the same vigor that it once did (even on its highest setting).
I decided i was going to check the error codes using the Continetal Imports diagnostic page (http://www.continentalimports.com/ser_ic40142.html)
Upon checking the codes i found the following:
E on the left side of the screen
FF on the right side of the screen
Does this have anything to do with my front fan????
Thanks in advance.
Old Jul 19, 2005 | 01:53 AM
why_not's Avatar
W212 2009, W115 Pullman & EQC
It seems like your blower regulator is bad.
Its a comon problem, and aesy to fix
Do a search and u will find a lot of info´about this.
Rgds kim
Old Jul 21, 2005 | 01:33 AM
JLLG's Avatar
1997 E320 2000 ML430
I think FF means you have no error codes.
Old Jul 21, 2005 | 01:44 AM
why_not's Avatar
.. The error codes will not show if the blower regulator is defect.
/kim
