Vibration
Old Jul 19, 2005 | 03:39 PM
Betty's Avatar
E280 V6 1999 Advantgarde 18in AMG's
Vibration
We have another problem..she shakes at about 50 to 60 MPH its not through the steering more the body and feels more from the back of the car..anyone any ideas had the wheels balanced had new brake dics all round....please help
Old Jul 19, 2005 | 03:43 PM
vraa's Avatar
What RPM are you at?
Do you think it could be the exhaust system just droning?
Old Jul 19, 2005 | 03:48 PM
Betty's Avatar
no not exhaust does it in nutral coasting makes no odds what the revs are
Old Jul 19, 2005 | 03:50 PM
vraa's Avatar
So you've narrowed it down that it isn't from your unsprung weight (wheels + brakes and such) and it's coming from the back.
Do you have anything installed in the rear that might act as a air diffuser? Could be because at that speed something is hitting hard?
Old Jul 19, 2005 | 03:54 PM
Betty's Avatar
realy not sure it doesnt matter what speed you are doing its always the same its like the car has the shivers...it was fine a few months ago and its just got worse no reason....
Old Jul 19, 2005 | 03:55 PM
vraa's Avatar
One thing that just hit my head since you said it's been getting worse is..
motor mounts. They could be worn out.
Old Jul 19, 2005 | 04:13 PM
Betty's Avatar
Hmmm I also think you could be right i had read on here that they seem to ware out what ever it is I am sure Mercedes will charge us a small fortune for the delight of driving on to their forecourt
Old Jul 19, 2005 | 05:38 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Could be a bad rear tire, bad belt or such. Balancing will not help that
Old Jul 20, 2005 | 06:47 AM
Rich VA's Avatar
97 E420 with 57k miles
Vibration
I have a 97 E420 with 60k miles on it. I have had the same problem for over 8 months and it was driving me crazy. After replacing a tire,which I was told had an excessive hop in it, the vibraton seemed milder but not gone. I thought maybe another tire was bad. I recently took the car to the dealer for its 60k service and told them I thought I had a bad front tire with an exsessive hop in it. The dealer came back and said that the left shock absorber was over heating and the lower front left and right control arms were leaking. The dealer replaced the left front shock absorber, both lower control arms and bushings as well as the upper right control arm and both front spring coils now the problem is completely taken care of. Thank goodness I had the starmark warranty and none of this cost me a dime. I was told the repairs would have been several thousands of dollars. Good luck.
Old Jul 20, 2005 | 09:42 AM
RobertG's Avatar
things with and without wheels
Try the lower cost items first such as tires and rims.
Wheel bearings and differential also are known to cause these symptoms too
Old Jul 20, 2005 | 09:51 AM
RobertG's Avatar
Question
Hey Rich
your control arms were leaking? what were they leaking?
Old Jul 20, 2005 | 06:38 PM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
I would have the rear tires re-balanced. Sounds like either one has thrown a weight or the belt on the tire has shifted.
Old Jul 21, 2005 | 06:51 AM
Rich VA's Avatar
Hi Robert, I took that information straight from the dealer invoice. I did not think they had fluid, and maybe they do not, that is just what they typed.
Old Jul 21, 2005 | 12:43 PM
RobertG's Avatar
CLERICAL ERROR :p
I think they ment to say that the shocks were leaking
Old Jul 21, 2005 | 07:56 PM
Ala-benz's Avatar
'00 E430, '83 Porsche 928S
My 97 E420 had, what sounds like, the same problem. The main culprit was a wheel that was out of round. I had the tires replaced, balanced, rebalanced, etc. The shop did not notice the wheel until I spoke with the tech on the floor. They try to balance out wheel problems (if they are minor). The wheel vibration transmitted to my steering wheel at 55mph to 65 mph. I ended up replacing my lower control arm bushings because they were also worn-out and making the vibration transmit even worse.
After a new set of wheels, it is doing very well. I still plan to replace my shocks in the near future.
Good luck with yours. Does anyone know if the KYB's on Ebay are any good? They are advertising them for $160 for the set of 4.
Old Jul 23, 2005 | 08:08 AM
Betty's Avatar
I think I will see what Mercedes say on thursday...It feels like the engine mounts or maybe a wheel egg shaped ...but we will see thanks for the advice we will post result..
Old Jul 28, 2005 | 05:08 PM
Betty's Avatar
Had the car checked they said all ok...but the tyres are worn the told us when we change them all will be ok we will see
Old Jun 18, 2006 | 11:06 AM
nkpnkp's Avatar
Flex disc
check your flex disc. Very common problems
Old Jun 18, 2006 | 12:04 PM
ehr1's Avatar
2002 E55 AMG, chevy truck,1984 190E(race car)
The lower control arm bushings are liquid filled. When the bushing breaks
the liquid will leak out.
Old Jul 5, 2006 | 02:16 PM
Ala-benz's Avatar
KYB off Ebay
I used the KYB's off ebay on my 2000 E-class. The front shocks feel very nice, but the rear shocks rattle your teeth over every bump. I went back to stock on the rear and I am running KYB in the front. Very nice ride with that set-up. I am also running stock height and 18" rims.
