E320 Mirror Problems
Old Aug 13, 2005 | 10:06 AM
71LS5's Avatar
1997 E320, 2001 SL500
The spring that allows the mirror to fold and pop back into place has come off inside the mirror housing. It is the driver side mirror. Is there a way to remove the mirror from the car and reattach the spring provided the attachment point is not broken off. Also can the mirror motor etc be removed from the housing? Appreciate any help. The car is a '97 E320
Old Aug 13, 2005 | 01:54 PM
Whitey's Avatar
98 W210 Advantgarde
This may help, watch and see...
http://www.edsoto.com/w210/media/w210%20k.mpg
Old Aug 13, 2005 | 02:40 PM
phatstyles's Avatar
e-klass
Im downloading the e320 informational CD. What kind of contect is on there. I was going to buy one of those dealership cds from ebay. Hopefully this will do the job. Thanks whitey.
Old Aug 14, 2005 | 12:26 PM
71LS5's Avatar
Mirror
Thanks Whitey that worked great.
Old Aug 14, 2005 | 01:17 PM
E-Klasse's Avatar
W205 C300
Once you remove the outer shell or cover then the motor and the spring can be accessed. The whole mirror comes off with just 3 screws.
Old Aug 14, 2005 | 01:55 PM
Whitey's Avatar
98 W210 Advantgarde
No need to thank me but we should all thank member EddieGTP for hosting the CD, a video sure is more effective than merely words
Old Aug 16, 2005 | 02:32 PM
cficpa's Avatar
Whitey:
I attempted to view the page that you displayed, but I keep getting the message "page not found." Is there another way to view it. I too have a broken mirror. Mine is the passenger side. I want to see if I can hook the spring onto something in the mirror case.
Many thanks!
Old Aug 16, 2005 | 02:46 PM
Whitey's Avatar
98 W210 Advantgarde
This is going to sound real corny but here it is:
" the site is down, please try again later"
Otherwise, I seem to remember a few other posts with pics and instructions (probably by E-Klasse who is one of the masters of DIY here )...Good luck.
Old Aug 16, 2005 | 02:51 PM
Whitey's Avatar
98 W210 Advantgarde
Here you go, pictures and instructions:
https://mbworld.org/forums/showthrea...ghlight=mirror
Old Aug 18, 2005 | 11:51 PM
cficpa's Avatar
Thanks Whitey. I will check it out.
Old Aug 19, 2005 | 12:21 AM
raymond g-'s Avatar
99 E320
I'll host this for a few days... mirror video from ISO
Old Aug 19, 2005 | 09:51 AM
SmokeSilver's Avatar
1997 E420
The piece that the spring attached to on mine broke in a car wash. My shop re-attached it to a different part for free. However, everytime I closed the door the whole thing rattled because the spring was no longer as tight as it should have been.
I finally had enough of that and found new guts for $156 (Drivers side) from Rad Tech. It is an aftermarket reproduction. Took about 10 minutes to install...works great! The OEM part goes for about $450-$550...no thanks.
Good luck
Old Aug 19, 2005 | 03:21 PM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
That video is quite enlightening but is only for the early 210. The later 210 with the light mirror doesn't have that spring. I still haven't figured out how to take the shell off. Any assistance would be appreciated.
