shimmy at 35-40 mph. Wear pattern on rear tire.
Old Aug 23, 2005 | 07:28 AM
30Spece30's Avatar
I have a 99 E320 4 matic wagon with about 100K on it.
The car has a distinct side to side shimmy right around 40mph and has worn the right rear tire in a weird pattern.
I thought the Right rear was actually bent (it still may be) so I swapped on the spare and it still does the shimmy, just not as bad.
Any ideas?
Thanks in advance!
RLB
Old Aug 23, 2005 | 05:48 PM
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
Any ideas?
Thanks in advance!
RLB
I had a similar problem, I had the suspension looked at, but the problem went a way when I replaced both rear tires.
Old Aug 23, 2005 | 08:33 PM
Highend's Avatar
C219 CLS / W220 † / W211† / W210 E55 † / W210 Brabus † / Hamann 540i † /
Thrust Arm Bushings
Old Aug 23, 2005 | 10:12 PM
E55Cent's Avatar
Originally Posted by Highend
Thrust Arm Bushings
How much are the bushings and what is the typical labor for a job like that? Can you just replace the bushings without anything else?
Thank you
Mario
Old Aug 24, 2005 | 01:00 AM
Highend's Avatar
Run you around $100.00 and another hondo to install. Plus most place will tell you need to re align the car after, but a friend of mine who owns a shop has a special tool that cuts the time in half and keeps the car allinged. If you live in Orange County and want this done he is an awsome guy and i'll give you his # All he does is Merc, BMW, Porsche, and Jags so he knows his stuff
Old Aug 24, 2005 | 01:45 PM
E55Cent's Avatar
Sounds great send me his info.
Mario
