e320 ?
Old Aug 24, 2005 | 03:42 AM
deuxslow's Avatar
W215
e320 ?
I'm looking at 00 ' e320, 68 thoudsand miles, asking 20 grand from a private seller. I'm offering 15 grand cash. What should I look for before buying this car, overall looks are clean. It still has the starmark warranty on it for 1 hundred thousand miles. what problems could I expect? Thank you, your help is much appriciated.
Old Aug 24, 2005 | 07:25 AM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
Make sure that:
  • all the windows + sunroof work
  • all other electronics work
  • A/C works
  • transmission shifts smoothly & no slippage
  • check for "groaning" noise when turning wheel (power steering rack)
  • check for rust:
    • under all 4 door seals (lift up on inside edge) and on bottoms of doors
    • on trunk lid near latch & below license plate
    • inside front wheel wells
Old Aug 24, 2005 | 08:34 AM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
Is the owner going to let it go for 15K? If so,sounds like a nice deal for you.I second the aforementioned points of concern,especially the rust spots.
You might want to do a carfax check,and confirm all the proper service appts. were kept.
Old Aug 24, 2005 | 08:43 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
The seller is nuts if he lets it go for 15K if all is as it should be.
Old Aug 24, 2005 | 09:52 AM
RobertG's Avatar
things with and without wheels
I second the carfax, take down the vin # see where it was seviced and see what was done to the car so far.If he's willing to let go of it for 15 that means something is fishy unless he has financial problems of some sort.17g's +- would be a good deal if the car is right.
Old Aug 24, 2005 | 10:57 AM
lexrex's Avatar
Just remember that a clean CarFax is not a guarantee of anything. The report is only as good as the information that's been given to CarFax. If it shows a problem, then you know there's a problem. If it doesn't show a problem, then you don't know either way. I've seen cars with visible evidence of prior collision repair with no record of the incident on CarFax.
Old Aug 24, 2005 | 03:36 PM
deuxslow's Avatar
W215
Here's a pic I took with my phone, sorry about the quality. More pics later.
Old Aug 25, 2005 | 03:08 AM
mazeta's Avatar
2000 E320
15K? Good luck getting it at that price...
Wholesale auction price on that car on that car is ~$16500 in less-than-perfect condition.
Service records, ask for service records. At 6 years old, the original alternator, water pump, and other parts may be starting to give out. Can get pricey to fix.
Old Aug 25, 2005 | 10:15 AM
deuxslow's Avatar
W215
You all have been very helpful. I'm only 21 and wondering if I should purchase this car. I also have 02 civic which is bullet proof so at least I can fall back on that. I used to work with mercedes in northern San Diego, I don't remember to many w210's coming all that often.
Old Aug 25, 2005 | 01:01 PM
OceanView's Avatar
W212 & W210
Wow, at $15K your stealing it.
You could buy it and try it. If you don't like it, you could sell it and get your money back.
