Weird noise from passanger side??????help
anyways as i roll from stop to about 30mph i can hear a tick tick or click click noise from the right side passanger........at first i thought it was the wheel but i had the car on a lift this morning and didn't see anything......i didn;t have time to stick around or anything but what do you guys think it can be?
It was worst over 100mph
I replaced the GF.. noice all gone now..
/kim
mine only get to see the backseat......
Check the bearing
Check the bearing
any help would be great.........thanks man
For the front wheels, the only case you can't really spin the wheels freely is if you brake caliber stuck. Try to lift the car and modulate the brake a bit (with the engine off), if you can't still spin the wheel, then it's definitely the caliber
For the rear: either the caliber, or more often: parking brake stuck.
just hear a ticking noise and it becomes faster as i go faster but at higher speeds i don't really hear it but only when i reduce my speed down to 20mph down to a roll........
