Vent control.......
Old Sep 23, 2005 | 12:22 AM
guitarplayer's Avatar
2023 GLC 300 4MATIC
Vent control.......
Am I doing something wrong? I only want the ac to blow out of the front vents only, not the floor and front at the same time. In hot weather with shorts on I don't want the cold air blowing on my legs. The vent control button only allows the front vents to blow along with the floor vents at the same time. Unless I am doing something wrong. Am I correct? If I am this is stupid. Every other car allows front vents only as an option. Cold air sinks, so I don't need even more cold air coming from the floor vent.
Old Sep 23, 2005 | 05:30 AM
why_not's Avatar
W212 2009, W115 Pullman & EQC
Well..
have u tried to run the flap test.. ??
/kim
Old Sep 23, 2005 | 05:33 PM
enzo430S's Avatar
MB E430 Sport
Yes I agree, I want front vents only...how do we do that??
Old Sep 23, 2005 | 07:46 PM
2023 GLC 300 4MATIC
I called my dealer today, said MB set the vent options upon mfg design and no front vents only. It is mixed with the floor vents at the same time. Completely stupid!!!!
Old Sep 23, 2005 | 11:09 PM
Rafael Grullón's Avatar
E420 Sport
Do you have the owner´s manual?
It explains how to make the dash vents to vent.
Maybe I´m wrong but dealer answer doesn´t seem accurate.
Old Sep 23, 2005 | 11:19 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
Right. The floor vents are controlled by the computer when on auto mode. You can select only the front vents using the vent direction switch. There should be one arrow, which points horizontally.
If you get floor vent air even when you manually set the direction, you probably have a flap problem. Run the flap test to know for sure.
http://www.continentalimports.com/ser_ic40142.html
Old Sep 25, 2005 | 03:26 PM
king_j's Avatar
the arrows in the manual mode piont to the front vents and the floor.
i do not have an option to go front only.
very stupid design. 97 E320.
my 1990 300E had the same controls, its just a M-B thing.
Old Sep 25, 2005 | 04:03 PM
2023 GLC 300 4MATIC
I figured it out. You can only get the front vents only with the manual mode.
Old Sep 25, 2005 | 04:28 PM
king_j's Avatar
which car?
both of the mercedes i have owned did not have a center vent only option.
only cold air would come through the center vent. warm air would come from the sides, windshield, or feet.
and this is on manual mode.
Old Sep 25, 2005 | 05:49 PM
2023 GLC 300 4MATIC
Which car? My car. 2002 E320.
Old Sep 26, 2005 | 01:49 AM
king_j's Avatar
im assuming the 2002 climate control unti is the same/similar to the 97.
anyway, today i had the ac on and it blew from the center vent, when i raised the temp to warm air would stop comming through the center vent. the direction arrow was facing up, i had heat comming from the windshield area and the side vents.
manual mode.
Old Sep 27, 2005 | 03:46 PM
mypantsaretorn's Avatar
2002 c320 wagon
usually when i have mine on auto it comes out only in the front vents... but for some reason when i use heat... i cant seem to get air to come out of the front vents..it only comes out of the top (defrost).. do any of u guys have this problem? it only happens with the heater tho... the ac works just fine...
Old Sep 27, 2005 | 06:28 PM
E-Klasse's Avatar
W205 C300
Arrows point to both front and floor...
Old Sep 27, 2005 | 08:50 PM
2023 GLC 300 4MATIC
That pic looks like windshield vent only to me.
Old Sep 27, 2005 | 09:44 PM
king_j's Avatar
arrows dont matter. the temp setting determines where the air will be released.
Old Sep 27, 2005 | 09:45 PM
king_j's Avatar
this is "normal"
dont know why, but ehh, what can you do?
Old Sep 27, 2005 | 10:07 PM
livetodrive's Avatar
2001 E-430 4-Matic
tornpants - your car is working as designed. The center dash vents are only for A/C. As far as I know, there's no way to get heat out of them.
