Radio replacement w/Sirius - which one?
Old Oct 9, 2005 | 12:27 PM
bingoldsby's Avatar
I'm a Sirius subscriber, with a radio installed on my Goldwing motorcycle. There's nothing like it (satellite radio general).
I am considering replacing the radio head in my 2000 E320 with one which is Sirius radio ready. In thinking about that now, I suppose that I would loose the steering wheel control functions by replacing the Mercedes radio with anything else. Is that about correct?
I do have another Kenwood set just like the one I have on the bike, which I could setup in the car, and I know how to add line-out circuitry so that I could plug it into some kind of auxillary input - which I suppose doesn't exist also.
Has anyone here solved some of these problems with a functional and acceptable solution for adding satellite radio to the MB? I don't want to remove the ashtray (don't smoke, but use the lighter plug for cellphone power). And I don't want to tape something to the dash - especially the bright silver-looking controller head that I have - ick!
And what's din-size or double din-size? I suppose it refers to the standard hole that a car radio fits in.
Thanks for any insite.
Brian - Yakima, WA
2000 E320
Old Oct 10, 2005 | 04:01 AM
stickygreen's Avatar
'97 E320
Kenwood EZ700SR...
This is the deck I plan to use in my e320 once funds become available. It has a built-in Sirius tuner & comes with an antenna:
http://www.crutchfield.com/S-2Qko44D...search=ez700sr
If you have the regular CD or tape deck (not COMAND/Nav unit), it should fit right in.
Raj
'97 e320
'05 e320 cdi
'85 535i
Old Oct 11, 2005 | 09:50 AM
bingoldsby's Avatar
Thanks, Raj,
Just the kind of suggestion I was looking for. I'll check it out and ask more about it if I need to.
Brian
