19 inch rims of on 4matic?
Tire size should be either 235/35-19 (0.7% difference from stock) or 245/35-19 (1.7% difference from stock; 245 is the size TireRack recommends for 19" rims).
The larger diameter wheels won't mess up your speedometer too much because the overall diameter of the wheel & tire remains fairly close.
If you go with the 245 size, you might have trouble using your stock spare tire because of the 1.7% diameter difference. Traction control might sense the speed mismatch between the spare and the 19-inchers and brake the spare.
Please keep me posted on this--sorry to dig up an old thread!
Maybe we could get a discount for ordering two sets? $500 is not bad at all if it comes with shocks or is a coilover kit.
-Cory
The Tirerack suggested "plus" tires sizes include the weight capacity for each tire. In some cases, by going down the next width size, so does the overall weight capacity. I am not sure if this is the case here, as I have not reviewed the differences of 19" tires.
