w210 removal of shift knob
Old Oct 25, 2005 | 02:55 AM
gtboxer's Avatar
i am upgrading to a brabus shift knob...how the *(^&%%$ do i remove the stock one. it is killing me. thanks for your help.
Old Oct 25, 2005 | 06:51 AM
carlsson9's Avatar
Mercedes W210 E280
just twist the bottom plastic piece anti clockwise and pull it out
Old Oct 25, 2005 | 01:48 PM
gtboxer's Avatar
tried that, it is not coming off, i twist it anti clockwise, but the knob is not coming off, does the bottom piece come off first?
Old Oct 25, 2005 | 02:01 PM
RobertG's Avatar
things with and without wheels
there is a chrome color coller under the knob you need to turn that and the knob will slide up
Old Oct 26, 2005 | 01:51 AM
MBZ12's Avatar
'07 R350. '05 C230. '93 454SS Truck. '71 Chevelle SS.
Come on bro, you can do it! This is probably the easiest mod that can be done.
Old Oct 26, 2005 | 03:30 PM
TruE320Ridah14's Avatar
2007 E550
removing the door pins is easier
Old Oct 26, 2005 | 03:33 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
or changing valve caps........
Old Oct 27, 2005 | 06:04 AM
carlsson9's Avatar
Mercedes W210 E280
maybe a pic of your gearknob? is yours the OEM knob or an aftermarket?
if it doesn turn you might want to use pliers and a piece of cloth to get some grip and twist it..
i had probs like that before, but i recently changed my knob to an original S class leather knob..happy with it..
Old Oct 27, 2005 | 02:11 PM
gtboxer's Avatar
it is oem, the bottom piece only turns anti clockwise like 90 degrees and does not fully come off, i tried pullling the knob off after turning, but it won't come off. please advice. thanks.
Old Oct 27, 2005 | 02:59 PM
Whitey's Avatar
98 W210 Advantgarde
Pull it off!
The ring releases the base of the inside of the knob which clamps onto the shaft. Wiggle it a little and pull hard if you need to, maybe its just fixed in place with age.
And no, the ring does not come off. 90 degrees is all that is needed.
Old Oct 27, 2005 | 07:07 PM
gtboxer's Avatar
the **** is not coming off, i think i am going to cut it.
Old Oct 27, 2005 | 08:20 PM
MBZ12's Avatar
Bolt cutters should work great for this...
Old Oct 28, 2005 | 09:16 AM
Whitey's Avatar
98 W210 Advantgarde
....and end up with a "short shifter"
Old Oct 28, 2005 | 01:12 PM
mbzmike's Avatar
1998 e420 ( 210 / 119 )
shifter
i once had a short gilfriend, 4'11 ! very short, but she could shift !( lol ) i left the f out accidentally the first go around on shift, hahaha )
Old Oct 28, 2005 | 01:32 PM
Whitey's Avatar
98 W210 Advantgarde
Hahahah, I saw on my email notification and thought WTF? LMAO
Old Oct 28, 2005 | 03:12 PM
mbzmike's Avatar
she shifts
no doubt, righton, i called her 3 speed for short !
Old Nov 1, 2005 | 12:17 AM
gtboxer's Avatar
the knob is off........the black and decker worked. thanks
Old Sep 5, 2011 | 10:40 AM
bng1959's Avatar
2017 S550 A217,2006 SL500,2002 CLK430
Thanks for this and many more I have found on this website. Was easy to change out my original with a new wood knob. Found the information here and also have replaced steering wheel. What a great site!!!
