Fuel Level
Old Nov 4, 2005 | 03:50 PM
hadam's Avatar
2007 S-550, 2001 E-430 & 1997 E-420
Question Fuel Level
I have been having this Intermittent problem with my fuel level in 97 E-420.
Most of the time my fuel level works fine and show me the right level on instrument cluster.
But once in the while, it goes to high and show full tank even though I had half a tank before.
So my problem is that my fuel level goes to high Intermittently.
I believe the problem is with sending unit.
Does any one know where fule level sending unit is located ?? Or the level sensor ??
Old Nov 4, 2005 | 05:39 PM
MB AMG's Avatar
2002 E55 AMG
Most likely the fuel sensor. I asked this question a year or so ago and who was... said it was a common problem in the W210's.
My E320 always fluctuates, showing lower than it actually is. The problem stopped but now it's back again...
Old Nov 4, 2005 | 05:40 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Its in the fuel tank. I believe very easy to get to and replace.However it could be the gage itself. Have it properly diagnosed by a dealer before throwing parts at it
Old Nov 4, 2005 | 05:50 PM
mbnj's Avatar
'06 E 350 4matic wagon; '05 E 500 4matic sedan; '09 S550 4matic
Yes, fortunately mine went under warranty. SA told me "they were all going". The replacement sender has worked flawlessly.
Old Nov 4, 2005 | 07:04 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Its located in the trunk...remove the trunk liner and the center trunk panel to access the fuel tank..the sender is on the side of the tank..do this job with less than a half of tank to avoid spilling fuel..The defective sending units are a KNOWN problem
Old Nov 5, 2005 | 08:27 AM
hadam's Avatar
Cool Location of fuel level sending unit
Mark, Thanks. I will check it out the fuel level sender today. I will try to access it from trunk.
I found attached PIC of sender.
