'96 E300 Diesel EDC problem?
Old Nov 15, 2005 | 04:03 AM
Caballero's Avatar
Exclamation '96 E300 Diesel EDC problem?
Hi gys,
What does this mean: "EDC Diesel electronic" this appear on my bord computer.
Does anybody experience such a problem?
When the weather is cold the car start difficult.
Is it possible to be from the sparkplugs or battery?
Thanks in advance
Old Dec 1, 2005 | 06:42 PM
Parrot of Doom's Avatar
W210 E300DT Saloon
I'd suggest that you check the glow plugs if its difficult to start on a cold morning - does it become easier when the engine is already warm?
Old Dec 2, 2005 | 08:32 AM
FlintCDI's Avatar
2005 E230 CDI
you may have better luck if
You post this in the new Diesel Forum! Welcome to the forum.
Old Dec 3, 2005 | 09:41 PM
michakaveli's Avatar
E300
Also check out www.MercedesShop.com, then go under forums - Lots 'o' diesel folks there.
With that message it's tough to say anything - I would have the codes scanned, as that message alone is worthless - For example, if you battery is almost dead or dead, with the engine running, you will get message like that all over the dash as it lights up like a Christmas Tree - does it run fine? Anything noticeably wrong?
