Tranny swap question E320
Old Nov 20, 2005 | 02:09 PM
michaelfrankie's Avatar
1997 E320 1985 300TD
Does anyone know if a 1998 E320 transmission (722.6) can be swapped into my 1997 E320 with a 722.6 tranny? Thanks!
Old Nov 20, 2005 | 06:56 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
I suspect you can, but it might require a control module / software update.
Just about every '97+ W210 model had a different transmission model number (722.6xx).
Old Nov 21, 2005 | 01:27 AM
Ben'z's Avatar
E320
Why not the 2000+ tranny? :p
Old Nov 21, 2005 | 07:14 AM
lexrex's Avatar
Ben'z has a good point. I'm guessing though that you've already located a 98 transmission?
I suspect that the '98 transmission is more likely to be compatible with your car than later transmissions. Mercedes made a number of reliability/durability improvements by 2000. However, if you get a '99 or later transmission, you'll lose the torque converter drain.
Old Nov 22, 2005 | 08:41 PM
is the 2000 a much better tranny? what improvements did they do?
