euro tailight problem?
Old Nov 27, 2005 | 02:38 PM
Gomez153's Avatar
97 e320
hey guys you know the taillights that come on when you pull the light knob all the way? well i saw that one of them didnt turn on so when i checked it out it had no light or socket the whole was stll sealed anyone have this problem?
Old Nov 27, 2005 | 04:41 PM
E43's Avatar
E43
2000 E430 Sport
I think only one light is supposed to come on when you pull the light switch all the way out.
Old Nov 27, 2005 | 08:06 PM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
The front fog lights turn on when you pull the light switch out to the first notch. The rear single (driver's side) fog light turns on when the switch is pulled out to the second notch (all the way). Before 1990 both sides would light up for the rear fogs but that created some confusion because the rear fogs looked like the brake lights so the manufacturers only installed the driver's side. This is a very good solution since you can better judge the distance to the car in front of you when you can see both the single rear fog and the normal tail light.
