Shift Knob Illumination?
Old Dec 9, 2005 | 01:22 AM
**OJack**'s Avatar
Just bought a E320 1996, (Previous E32 735i owner) and I am not sure if the PRND indicator is supposed to be illuminated? Is there a bulb that might have burnt? If so can someone provide me with the instructions on how to replace the bulb.
Thanks in advance
Old Dec 9, 2005 | 03:44 AM
carlsson9's Avatar
Mercedes W210 E280
yep, it is suppose to be litted up.
just pop open the gear box casing and you'll see the bulbs inside. mine blew few months ago..not too sure of the bulbs, but its an easy job..
Old Dec 9, 2005 | 11:02 AM
**OJack**'s Avatar
I opened the trim (black plastic rectangular) around the shift knob and PRND32. How do I remove the gear box casing? Is it the flexible corrugated black plastic or are we talking about the solid plastic illumination PRND32?
Thanks for helping me.
Old Dec 9, 2005 | 08:48 PM
carlsson9's Avatar
Mercedes W210 E280
You're gonna have to pop up the lower part wood grain panel, and then take out the autobox cover..I saw it being done once, but that was months back..I know it was an easy job, and it should just pop right off..there are two different bulbs inside...onc of it could be burned. Sorry i can't help you out further..good luck!
