Anyone replaced rear strutts on a W210?
One of the things that I wonder is, do I need any special equipment or does the springs have to be removed to change the strutts?
I don't remember too many people doing it themselves.
Anyone have any suggestions or recomendations?
All you have to do is lift the car, remove some of the trunk interior to get to the top of the shock nut. You most likely will need a air impact to get the nut off, not because it is night, but because the shock piston will keep spinning. Remove the bolt on the bottom and remove the shock. I did mine and didn't even remove my rear tires. The whold job should take you one hour.
Good luck
Mario
For some reason, I thought we had strutts on these cars.
It seems to be a pretty straight forward remove and replace job.
Will attempt it over the holidays.
I like saving money if I can.
