climate control
Old Dec 23, 2005 | 06:03 PM
king_j's Avatar
climate control
i have a 97 E320.
if its approximately 45 degrees outside, and i set the climate control unit to 70 degrees, it should blow at 70 degrees. but it blows cool air.
now, this is in manual mode.
it will blow warm air if i set the temp to "HI"
now, if its 20 outside and i set it to 70 inside, it will blow at 70 like it should.
why is the outside temp. controling the inside temp?
Old Dec 24, 2005 | 12:17 AM
eLemnt | 0ne's Avatar
AC Schnitzer E46
Run a dianostic on your climate control. I can't find it here, but there was a website that explained how to troubleshoot your AC.
Sounds to me like a temp. sensor is gone bad. It costs 40 bucks for the sensor at your local MB.
Old Dec 24, 2005 | 12:24 AM
AC Schnitzer E46
Your in luck... I found it for you.
Yippie!
http://www.continentalimports.com/ser_ic40142.html
Old Dec 24, 2005 | 02:20 PM
king_j's Avatar
thanks.
but the link is more for A/C problems.
i have heat problems.
Old Dec 24, 2005 | 04:09 PM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
It sounds like you may have a sensor problem. Follow the diagnostics to see what the sensors are reading.
Old Dec 27, 2005 | 11:32 PM
AC Schnitzer E46
Originally Posted by king_j
thanks.
It does more than just diagnose AC... it does a lot more, if you actually read the whole page.
Good luck
