which are the springs
Old Dec 26, 2005 | 12:03 AM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
i have a 96 e320 with 19s. i am going to lower the car, but need some advice. some of the options is the eibach pro kit and the h and r sport springs. i am trying to get the lowest drop possible. which springs would be right for me? and what are pads, and what are the differences between them?
Old Dec 26, 2005 | 12:44 AM
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
H&R's are the lowest but ride a bit stiffer than Eibach. I have H&R with #1 pads. #1's are 5mm. 2 are 9mm, 3 are 13, 4 are 17. Most stock cars come with #3's. You might have to roll your fenders if your car is too low for you wheels offset.
good luck, check the search button there are many threads on this topic.
Welcome to the board.
Mario
Old Dec 26, 2005 | 11:03 AM
AKnight55's Avatar
what are pads though and the lower the pad the lower the car? also how much and where can u get them?
Old Dec 26, 2005 | 11:46 AM
ClayJ's Avatar
ON PROBATION
Eibach's ride a little more comfortably, H&R's should result in a bigger drop.
Old Dec 26, 2005 | 11:54 AM
AKnight55's Avatar
i finally know what the pads are now. i went to a website, but only could find #2 pads in the front and #1 pads in the back. would that be good? or is #1's all around the best? any websites are good.
Old Dec 26, 2005 | 02:30 PM
E55Cent's Avatar
For my E55, MB doesn't make #1 pads so I just used #1 pads from a E430. (which is the same thing)
It all depends on how you want your car to sit. I put #1's in the front because I like the "rake look" and I knew my two 12" subs would lower the back as well.
Since you want the lowest drop, I would call the dealer and get #1's for the front. I think they cost about $7.00 each. Also sometimes when the car is first lowered with new springs, till will take a month or so for the car to fully settle. My car dropped another 1/4" over a two month period.
Old Dec 26, 2005 | 02:40 PM
AKnight55's Avatar
mario you said you had to roll your fenders, if i were to go with a #2 pad in the front and a #1 pad in the rear, would i have problems with rubbing and would it sit in a nice stance. the only reason i wouldnt want #1's in the front is beacuse i wouldnt want problems with rubbing. i really do like the stance of your benz.
Old Dec 26, 2005 | 02:56 PM
E55Cent's Avatar
Thanks, with my old 19's staggered I had no rubbing problems, but once I got my HRE's I had rubbing issues front and back and clearing the brake claipers was big problem in the rear. I'm only clearing the rear brakes by .75mm (about a business card). Rubbing issues really depends on how wide you are going to go and the offeset of your wheels.
I have 245-35-19 front, 275-30-19 rear. AMG have their fenders factory rolled.
Old Dec 26, 2005 | 05:27 PM
AKnight55's Avatar
do u think #2's in the front and #1's in the front would look fine? or would the front look a little funny? or do u think i should go with #1's all the way around. i have 245/35/19 all around with the rims 19x8.5 all the way around?i want to go as low as possible without rubbing obviously.
Old Dec 26, 2005 | 07:26 PM
topdeez's Avatar
2012 E350 4matic/97 e320 and 01 ml320
I have h&r cupkit with #1 pads all around...
Old Dec 26, 2005 | 07:49 PM
E55Cent's Avatar
With only 245's you could use #1's, no problem. Drop it.
Old Dec 27, 2005 | 12:38 AM
AKnight55's Avatar
mario thanks for your help, your car looks great!
Old Dec 28, 2005 | 12:40 AM
AKnight55's Avatar
anyone have any #1 pads for the front or rear of a 96 e320? or is it the easiest to just go to the dealership?
Old Dec 28, 2005 | 02:08 PM
topdeez's Avatar
Much easier to get them from the dealer.
