Please post info on the door seal recall (#200503005)
MetroCard
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
from All-data dot com
TSB Number & Issue Date TSB Title
2005030005 MAY 05 Campaign - Door Frame Corrosion
i posted text before but cant find them. try SEARCH
.....found it
.....found it
2008 Aspen, 1970 Corvette, 2000 Corvette and 2009 Legacy Limited
'02 E430 SE, '02 Avalanche Z66, '06 R-350
I followed the link above for my 02 430. This is just too much, but they won't give details unless you pay them. Is this genuine?
What is the difference between Recalls and service bulletins, and what is the dealer's responsibility in the case of the bulletins?
General Recalls
Service Bulletins
S-07_61-039B JUN 05 Engine Controls - Adaptation Fault Code Diagnostics
P-67_30-12 DEC 04 Body - Side Window(s) Open After One-Touch Closing
P-30_30-61 DEC 04 Cruise Control Inoperative
P-82_10-419 DEC 04 Lighting - Condensation in Headlamps
P-32_25-19 DEC 04 Suspension - Shock/Strut Replacement Guidelins
P-91_10-83 OCT 04 Interior - Seat Cushion Rocks Makes Cracking Noises
P-27_00-47A OCT 04 A/T - 722.6 Oil Leaks From Electrical Connection
P-88_30-36 OCT 04 Body - Scraping Noise From Transmission Tunnel Area
P-82_00-260A AUG 04 Audio System - CD's Won't Play or Eject
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
P-83_40-68 OCT 03 A/C - Unnecessary Blower Motor Replacement
P-82_60-292 SEP 03 Audio System - Volume Knob Damaged
P-82_85-288 SEP 03 COMAND(R) System - Unable to Enter New Destination
P-07_07-34 JUL 03 Engine Controls - MIL ON/Multiple DTC's Set
P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
P-46_20-12 JUL 03 Steering - Squeaking Noise
P-82_10-257 JUN 03 Lighting - Headlamp Bulbs Inoperative
P-82_10-256 JUN 03 Lighting - Condensation In Fog Lamps
P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
S-07_61-27A MAR 03 Engine Controls - ECM Reprogramming Procedure
P-07_65-31 FEB 03 Engine - High Oil Consumption
P-80_57-20 FEB 03 Audio System - RF Interference Explanation
P-82_85-210 NOV 02 Navigation/GPS System - Various Malfunctions
P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
S-82_70-135B OCT 02 Fiber Optics System - Configuration/Version Coding
S-82_85-205 SEP 02 COMAND(R) System - Various Malfunctions
P-82_85-198 JUL 02 COMAND(R) System - No Sound/Whistling
P-47_10-16A FEB 02 Instruments - Fuel Gauge Inaccuracy
P-47_10-23 FEB 02 Fuel System - MIL ON/DTC P03XX (Misfire)
S-82_70-179A FEB 02 Cellular Phone - V60 Programming Instructions
P-80_30-13 NOV 01 Smart Key(R) - Download Time
P-47_20-17 OCT 01 Fuel System - Hard Start After Fuel Filter Replacement
P-40_10-33A OCT 01 Tires - Approved Winter/Summer Tires
P-82_85-170 SEP 01 COMAND(R) System - Incorrect ETA Calculation Displayed
P-82_85-171 SEP 01 COMAND(R) System - Instrument Display Not Centered
P-80_57-11 AUG 01 Ignition System - Electronic Ignition Switch Replacement
P-18_40-14 AUG 01 Engine Controls - Implausible Oil Level Messages
P-01_00-10 AUG 01 Alternator - Mounting Bolt Identification/Application
P-91_60-48 AUG 01 Air Bag System - Side Impact Sensor Replacement
2000100002 AUG 01 Front Longitudinal Members - Subsequent Coating
P-99_00-265 JUL 01 Vehicle - Technical Information Update Announcement
P-40_10-37 JUN 01 Wheels/Tires - Short Design Lug Bolts
General Recalls
Service Bulletins
2001 E430 Sport
I have the same question. Just as much info on my 01 430 but I don't understand the difference between a recall and a service bulletin and what responsibility the manufacture has???
service bulletins are not mandated fixes. can be done for free but you can
also end up paying, espec if out of warranty.
service campaign and/or recalls are federally required fixes...at their expenese
even if out of warranty
i can get you details of recall/tech bulletins free but will only do a couple .
identify yr/mk/model/engine/ and bull #
Raymond-g can yoy look this up my car is a 99 E430.
Thank You
Thank You
So the door frame corrosion is a recall that means the dealer has to fix it even if the car has no warranty?
the answer should be 'yes' but i'm unable to lay my hands on my notes and
the reference I've seen. so i Googled it (and you can as well)....if you want
to explore further.
to explore further.
when i got my other car's TSBs or Recalls fixed, they put a little sticker in the engine bay showing proof of correction. I was wondering how to find out if the TSB or Recall was fixed on a Benz. I just got the car used with 44k its an 02 e320 and was wondering if I need to take care of any TSB or recalls.
humming exhaust
Hello All,
Does anyone have more detail on the bulletin:
I drive a 1999 E280 and my exhaust sounds like it is a sports one...and a cheap one at that, already had the dealer replace one of the cats and the erst of the exhaust....should be super quiet but it is not. Especially around 3000 rpm's it drones like hell and at hoigher speeds my benz sounds like a volgswagen gti with noisy pipe...... Maybe something in the way the exhaust is suspended?
Thanks,
Marc
Thanks,
Marc
