Windshield Wiper Noise
Old Jan 10, 2006 | 11:21 AM
MB_E430's Avatar
2007 C230 Sport
I did a search but cannot seem to find the solution.
Problem:
At around 60 mph there is an annoying vibration coming from the wiper blade.
I live in Florida where it rains a lot so Yes the blade is changed frequently.
Do I need a new arm with stronger spring? I have heard this is a common problem. Any help would be appreciated.
Old Jan 10, 2006 | 11:46 AM
E-Klasse's Avatar
W205 C300
There was an issue with the plastic under the wiperarm that goes along the bottom of the windshield making noise while driving at highway speed. The fix was to install weather stripping on the back side of it where it contacts the windshield.
Old Jan 10, 2006 | 11:56 PM
W210 E55's Avatar
W210 E55
any more details on how to fix it? I have the same problem too.
thanks.
Old Jan 11, 2006 | 12:14 PM
E-Klasse's Avatar
W205 C300
Get some foam weather stripping at Home Depot. It should be 1/4 inch thick by about 1/2 wide with adheasive on one side. Pull the plastic up at the base of the windshield at one corner and install the stripping on the back side of it. When you let the palstic go back in to place, you will not even see the weather stripping. The sound caused by it vibrating at high speed will be gone.
Old Jan 11, 2006 | 09:39 PM
W210 E55's Avatar
W210 E55
Thanks, I will try that on the weekend.
Old Jan 12, 2006 | 07:07 PM
Edison_Chen's Avatar
Toyota Camry SE
I have a W220 is it the same for them too??
Old Nov 8, 2007 | 09:50 PM
hadam's Avatar
2007 S-550, 2001 E-430 & 1997 E-420
Wiper Noise around speed of 60 MPH and more
I am having wiper noise from windshield when driving my 1997 E-420 on freeway above 60 MPH. It is really loud some day.
Can someone explain in more detail how to install this weather striping to get rid of this noise.
Old Jan 14, 2008 | 08:05 PM
stan23's Avatar
2001 Porsche 911 C4
Same problem here... but slightly different. I am hearing some vibration noises coming from the wiper at around 40mph. Goes away at higher speeds. At first I thought it was coming from the dash, but If I activate the wiper, the noise disappears.
Old Jan 15, 2008 | 12:27 PM
E-Klasse's Avatar
W205 C300
Pull back the plastic up at the base of the windshield. Install the stripping on the back side of the plastic so that the weather stripping is between the plastic and the windshield. When you let the plastic go back in to place, you will not even see the weather stripping.
Old Jan 16, 2008 | 01:01 AM
Rostam's Avatar
97 420
I had the same problem. Put the weatherstripping in and it worked perfectly.
Old Jan 16, 2008 | 02:29 PM
stan23's Avatar
2001 Porsche 911 C4
what is the plastic piece i'm supposed to lift up and put weatherstripping on? Sorry for the dumb question!
Old Jan 16, 2008 | 03:06 PM
E-Klasse's Avatar
W205 C300
The whole moulded black plastic part that goes from one side of the windshield to the other and is under the wiper. Look where the hoop stops and to where the windshield begins and the plastic part in the middle will need to have weather stripping on the bottom side where it touches the windshield.
Old Jan 16, 2008 | 03:33 PM
stan23's Avatar
2001 Porsche 911 C4
Thanks! Helpful as ever I'll try this out tonight. Any specific size weatherstripping? I suppose this is something I can pickup from my local Home Depot.
Old Jan 16, 2008 | 09:37 PM
E-Klasse's Avatar
W205 C300
I used 1/4 inch thick by about 1/2 wide with adheasive on one side from Home Depot.
Old Jan 17, 2008 | 04:37 PM
stan23's Avatar
2001 Porsche 911 C4
I assume you put the adhesive side on the windshield itself? Thanks again!
Old Jan 17, 2008 | 07:37 PM
E-Klasse's Avatar
W205 C300
Actually, it was easier to stick it to the back of the plastic so that it hides under it. So the sticky side goes on the plactic and no the glass. If you ever have to have your windshield replaced, the weather strip will still be there.
Old Jan 18, 2008 | 06:19 PM
hadam's Avatar
I am still confuse on under which plastic piece I install weather stripping
E-Klasse can you see the photo of my MB and can you mark up or point to where I need to put this striping so I can get rid of this horrible noise coming out of windshiel.
Thanks in advance for your help.
Old Jan 20, 2008 | 12:57 AM
E-Klasse's Avatar
W205 C300
It is about where the white line is...
Old Jan 30, 2008 | 06:23 PM
hadam's Avatar
THANK YOU E-KLASSE - It worked.
Thanks for you help.
I fixed this noise issue. You were right; noise is not from wiper but from weather striping on windshield.
I used to hate this noise, now completly gone.
I did following.
There are 2 weather strips on windshield right and left, nothing in middle where wiper motor is.
On right weather wind shield strip (moulded black plastic) I remove one Philips screw on one corner side and slide weather striping to left and it came. Then I apply new foam strip on it and re installed it.
On left weather wind shield strip (moulded black plastic) I remove one Philips screw on one corner side and slide weather striping to right and it came. Then I apply new foam strip on it and re installed it.
Now I don’t have this annoying noise from my windshield.
THANK YOU E-KLASSE.
Old Feb 3, 2008 | 02:37 AM
maximus.a's Avatar
E320 1996
hmm... maybe ill try this out i always thot it was some debris in the areas by the windsheild because i used an air pump to blow things out and it was quiet once again
