2000 E320 license plate light
The process is very simple to do it will take about 10mins. There are 17 plastic push pins holding the liner in place, and 2 that are located on the arm of the trunk not sure what the correct name is for the arm but those will stay in. You will need to use a small flat head screwdriver, or the specified tool recommended for removal of push pins. Remove all the push pins (17) then you will be able to lower the liner down enough to get to the light assembly. You will need to be careful when you are removing the top hat of the push pin with screwdriver the may break.
Part # 6418 (C5W) Sylvania
Please excuse the grammar.
Just went through this on friday. I removed the top pins (nearest to the light) and a few more on the vertical side of the trunk. Becareful with these pins, they're fragile and about 2 bucks a pop if you break them. I used my fingers and pried out the pins.
Once you get to the lights, you have to squeeze the outer clips of the lights while you're holding the trunk lid. It's kind of awkward, but you'll understand the sequence once you have everything apart.
-travis
