Instrument cluster stoped working!
95 E300D
Yesterday my instrument cluster just died,on my 96 E320,non of the arrows is working.Any ideas of whats goin on?????? thank you.
Do a search for Diagnostic Mode. You can check all of the readings that should be displayed on your instrument cluster on you climate control module. Holding the REST button in for 10 seconds gives you a list of readings including speed and tach. If you are still getting readings then you may just need to replace the instrument cluster. They are on ebay a lot for under $100.
Before you jump ship, check the fuse for the guages. I have a 202 and found that if the "lamp failure warning system" fuse is removed, the guages would not work. It may be differentfor a 210 but I think worth looking at.
95 E300D
Thanks for help guys?
Well i just did this REST button thing,it shows me some numbers,i did find out one of them its RPM number,rest of those numbers have no idea what it means.And regarding instrument cluster from ebay,my friend bought instrument clusters from ebay,and it didn't worked properly.Dont know what the problem was but,none of them worked properly.
#6 is Coolant Temp.
#21 RPM
#22 Speed
Did u solve this problem? or find another Cluster?
