What spring pad # on W210 E200K?
Old Nov 12, 2007 | 10:07 AM
MoNd3sTo7's Avatar
W210 E200K
I just got lowered my car buy 1 finger in front and 2 finger at the back.. But i want a little higher at the front by 2 finger and i dont know what spring pad # i should get.. Thanks
Old Nov 12, 2007 | 10:35 AM
raymond g-'s Avatar
99 E320
part #s for the spring pads for W210:
Front
210 321 01 84 5mm
210 321 02 84 9mm
210 321 03 84 13 mm
210 321 04 84 17 mm
210 321 05 84 21 mm
rear
210 325 01 84 5 mm
210 325 02 84 9 mm
210 325 03 84 13 mm
210 325 04 84 17 mm
so, whatever your current spring pads are, buy
the pad which increases the current by 2 fingers
worth. this may not be possible if you're already
using #3 in the front, as the largest possible would
only add 8mm
Old Nov 13, 2007 | 09:00 AM
MoNd3sTo7's Avatar
W210 E200K
Thanks raymond it's reli help.. But i need to find out wat no# spring pad on my car first..
Old Nov 13, 2007 | 10:52 AM
raymond g-'s Avatar
99 E320
whoever did the lowering may (should) have noted this while they had the
spring off. if not, it is still possible to perform a visual check after pulling off
the wheel. strong light and ET like fingers may reveal the nubs
Old Nov 14, 2007 | 05:00 AM
MoNd3sTo7's Avatar
W210 E200K
Thanks Raymond I also just find out the dot today from Mercedes agent.. will check it up soon..
