Winter and Summer Transmission?
Thank you guys for all the help with all my simple questions.
1. Fuel economy. Intuitively, you'd think that starting in second gear would get better gas mileage. There was a thread from a year or two ago discussing real world gas mileage figures of both modes. It appears that gas mileage is slightly better in standard mode with 1st gear starts. Best guess: Starting in 2nd gear slips the torque converter more, wasting energy that could otherwise have been used to move the car in 1st.
2. If you always leave it in winter mode, you'll never use first gear. I don't know if this is true or not, but it's probably good for the transmission to occassionally "exercise" first gear. For the same reason, you wouldn't want to always use standard mode, otherwise you'd never use your second reverse gear. (Yes, there are two reverse gears.)
The transmission is provided with a selector switch for Standard "S" and Winter/Wet (snow and ice) "W" program modes.
Standard Mode
Press switch on symbol "S". Use this mode for all-regular driving. The vehicle will start out in 1st gear.
Fast On = Depressing the accelerator pedal quickly (not into kickdown position) while driving continuously, rather than depressing the accelerator pedal in the usual manner, will cause the automatic transmission to shift down into a lower gear. This gear shifting process is dependent on the current vehicle speed.
Fast Off = There will be no upshift when releasing the accelerator pedal quickly, e.g. using the engine's braking power during performance driving.
Winter/Wet (snow and ice) Mode
Press switch on symbol "W". The vehicle starts out in 2nd gear, except with selector lever in 1st gear, or with accelerator pedal in kick down position.
The "W" mode helps to improve traction and driving stability of the vehicle. The gear shifting process occurs at lower vehicle and engine speeds than in the "S" program mode.
Caution! Never change the program mode when the selector lever is out of position "P". It could result in a change of driving characteristics for which you may not be prepared.
Important! Always be certain of the program mode selected since the vehicle driving characteristics change with the selection of the program mode. Dependent on the program mode selector switch position "S" or "W" and the gear selector lever in position "R", the ratio of power transmission changes.
