Vibration under car???
Old Apr 16, 2006 | 11:58 PM
cneedham810's Avatar
01' E Fifty Five
2000 E-320 -I have a small vibration under my car when i'm driving at speeds around 40mph, its very slight and does not happen all the time...i can feel it directly under my feey, any ideas or similar problems...
Old Apr 17, 2006 | 09:35 AM
smazur's Avatar
1. wheels out of balance, make sure to have them checked for both inside and outside balance wieghts.
2. tie rod ends.
Old Apr 17, 2006 | 02:33 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
Is it worse on cold days/when car is cold and goes away as the car warms up? Could also be tire flatspotting or worn flex discs. A lot of members, especially 4Matic owners, notice this.
Old Apr 17, 2006 | 04:30 PM
01' E Fifty Five
I have recently changed my set of wheels from the 17" double spoke to the 19" brabus mono VI, i noticed the vibration well before switvhing the tires so i'm not sure it has to do with balancing...if any oif these are the problem, am I looking at a big deal?
Old Apr 17, 2006 | 04:55 PM
01' E Fifty Five
since ive only had this car in the winter it may have to do with being cold so yes that is a possibility, its been warming up but still there are cold nights.
Old Apr 17, 2006 | 07:20 PM
jd986s's Avatar
I have the same problem. It happens when I let the gas go at 40mph. If my foot stay on the gas, it's not as bad. Turns out to be unbalance drive shaft. Dealer replace the drive shaft on my car and haven't notice the vibration.
Old Apr 17, 2006 | 10:24 PM
01' E Fifty Five
Thank you jd986s, any idea of how much i'm looking at to replace or know if there are any concerns if i don't replace it soon?
Old Apr 17, 2006 | 11:15 PM
Z06EATER's Avatar
1997 C36AMG
hi
had that done on my S320 it's gonna be around $200 not, as bad as i thought it was, they also repaced a rubber bearing.
GOOD LUCK!
Old Apr 17, 2006 | 11:35 PM
01' E Fifty Five
thanks everyone, i appreciate the help
